Salta al contenuto principale
Headphone Plug Replacement
Cosa ti serve
    1. Headphone Plug Replacement, Audio Jack: passo 1, immagine 1 di 2 Headphone Plug Replacement, Audio Jack: passo 1, immagine 2 di 2
      • Unscrew the casing from your replacement plug.
      Chiedi a FixBot
      Aggiungi Commento
    2. Headphone Plug Replacement: passo 2, immagine 1 di 3 Headphone Plug Replacement: passo 2, immagine 2 di 3 Headphone Plug Replacement: passo 2, immagine 3 di 3
      Strumento utilizzato in questo passaggio:
      Digital Multimeter
      $59.95
      • Using a multimeter (set in ohms to test resistance), test each terminal on the base of the plug to see which terminal corresponds to which speaker (left or right). You'll know they correspond when a value other than 1 appears on the multimeter.
      • Image 3 shows which part of the plug corresponds to each cable:
      • Left
      • Right
      • Common (or ground)
      • My results showed that the terminal with the larger hole corresponded to the right speaker, while the terminal with the smaller hole corresponded to the left speaker. Your results may differ.
      Chiedi a FixBot
      Aggiungi Commento
    3. Headphone Plug Replacement: passo 3, immagine 1 di 2 Headphone Plug Replacement: passo 3, immagine 2 di 2
      Flush Cutter
      $34.95
      • Using your wire cutter, remove the broken 3.5mm plug from the wire.
      Chiedi a FixBot
      Aggiungi Commento
    4. Headphone Plug Replacement: passo 4, immagine 1 di 3 Headphone Plug Replacement: passo 4, immagine 2 di 3 Headphone Plug Replacement: passo 4, immagine 3 di 3
      Wire Stripper
      $34.95
      • Use your wire stripper to expose about 2cm of the the wire.
      • You must also remove the coating from each smaller, individual wire by using a wire stripper, fine sandpaper, or something of that sort.
      • If you attempt to solder the wires without removing the coating, the connection most likely will not work.
      Chiedi a FixBot
      Aggiungi Commento
    5. Headphone Plug Replacement: passo 5, immagine 1 di 2 Headphone Plug Replacement: passo 5, immagine 2 di 2
      • Slide the casing (from Step 1) onto the wire.
      • You'll have to screw this back onto the plug at the end, so be sure it's facing the correct way.
      Chiedi a FixBot
      Aggiungi Commento
    6. Headphone Plug Replacement: passo 6, immagine 1 di 3 Headphone Plug Replacement: passo 6, immagine 2 di 3 Headphone Plug Replacement: passo 6, immagine 3 di 3
      Helping Hands
      $9.99
      • Helping hands may be helpful when soldering. If you have never soldered before, check out this soldering technique guide.
      • Slide the red wire through the hole of the terminal that corresponds to the right speaker. Wrap the wire around the terminal a few times, then solder it in place.
      • Repeat this step for the terminal that corresponds to the left speaker. Note that the left audio wire is often white or green.
      • Finally, solder the common/ground wire (often copper colored) and any multicolored wires through the remaining hole.
      • The pictures show a blue wire and several yellow wires. The blue wire was soldered with the ground wire, and the yellow wires turned out simply to be nylon (not actual wires).
      Chiedi a FixBot
      Aggiungi Commento
    7. Headphone Plug Replacement: passo 7, immagine 1 di 1
      • To finish, screw the casing back onto the plug.
      • Be sure the two terminals (or connecting wires) do not touch each other; if they touch, the fix will not work properly.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
If the fix did not work, make sure the wires are in direct contact with the terminals. Also make sure that they are not in contact with each other. If done correctly, your trusty pair of earphones (or headphones) can be trusted for quite a while longer!
Altre 27 persone hanno completato questa guida.
Andrew Yoder
Membro da: 04/09/15
1.141 Reputazione
Una guida realizzata
Cal Poly, Team 28-4, Green Spring 2015 Membro di Cal Poly, Team 28-4, Green Spring 2015
CPSU-GREEN-S15S28G4
6 Membri
24 guide realizzate
2Commenti sulla guida
The first sentence in your introduction can maybe be changed to: "Often times one earpiece of the earphones stop working."
Your description is well-written and thoroughly describes the process. I would just add pictures specifically pointing to the different parts you mention in your steps.
Otherwise it's all good! :)
Salonee - Rispondi Condividi
Is there a special fix for earphones with a control unit embedded?
Marcel Alani - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 5
Ultimi 7 giorni: 61
Ultimi 30 giorni: 260
Tutti i Tempi: 63,165
