Introduzione
Follow this guide to remove the rear padding from your HTC Vive XR Elite.
If your battery is swollen, take appropriate precautions.
Cosa ti serve
Insert a long edge of an opening pick in the gap between the two halves of the battery cradle, near the USB-C cable.
Slide the opening pick along the top edge of battery cradle to release its plastic clips.
Slide the opening pick along the bottom edge of battery cradle to release its plastic clips.
Pull apart the two halves of the battery cradle to completely separate them.
Use a T5 Torx screwdriver to remove the four 4.9 mm-long screws securing the rear padding.
Pivot one of the rear padding clips toward the center of the frame.
Lift the rear padding up to unclip it.
Unclip the remaining rear padding clip.
Remove the rear padding.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
