Salta al contenuto principale
HTC Vive Focus Rear Head Strap Replacement
Cosa ti serve
  1. HTC Vive Focus Rear Head Strap Replacement, Unscrew the head strap mounts: passo 1, immagine 1 di 2 HTC Vive Focus Rear Head Strap Replacement, Unscrew the head strap mounts: passo 1, immagine 2 di 2
    • Use a T6 Torx screwdriver to remove the four 4.6 mm screws securing the rear head strap, two on each side.
  2. HTC Vive Focus Rear Head Strap Replacement, Disconnect the rear head strap: passo 2, immagine 1 di 3 HTC Vive Focus Rear Head Strap Replacement, Disconnect the rear head strap: passo 2, immagine 2 di 3 HTC Vive Focus Rear Head Strap Replacement, Disconnect the rear head strap: passo 2, immagine 3 di 3
    • Remove the plastic cover from the rear head strap mount.
    • Lift the rear head strap off of the two pegs securing it to the mount.
    • Repeat for the remaining side of the rear head strap.
    • During reassembly, be careful not to install the rear head strap upside-down. The adjustment knob on the back of the head strap should be on top.
  3. HTC Vive Focus Rear Head Strap Replacement, Remove the rear head strap: passo 3, immagine 1 di 1
    • Remove the rear head strap.
Conclusione
Sam Omiotek
Membro da: 02/25/19
73.741 Reputazione
288 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 9
Tutti i Tempi: 171
