Salta al contenuto principale
HP ProBook 640 Fan Replacement
Cosa ti serve
  1. HP ProBook 640 Fan Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the laptop upside down to show the battery lock slider.
    • It is a black slider near the top, with a battery logo to the left and a lock sign to the right.
    Chiedi a FixBot
    Aggiungi Commento
  2. HP ProBook 640 Fan Replacement: passo 2, immagine 1 di 1
    • Slide the battery slider all the way to the left, towards the battery symbol.
    • You may also need to slide the other slider to the right of the battery slider, as shown in the picture.
    Chiedi a FixBot
    Aggiungi Commento
  3. HP ProBook 640 Fan Replacement: passo 3, immagine 1 di 1
    • Remove the battery by sliding it away from the laptop while holding the battery locker.
    • The battery should slide out with ease.
    Chiedi a FixBot
    Aggiungi Commento
  4. HP ProBook 640 Fan Replacement, Back Panel: passo 4, immagine 1 di 2 HP ProBook 640 Fan Replacement, Back Panel: passo 4, immagine 2 di 2
    • Slide down and pull up on the cover to remove it.
    Chiedi a FixBot
    Aggiungi Commento
  5. HP ProBook 640 Fan Replacement, Midframe: passo 5, immagine 1 di 3 HP ProBook 640 Fan Replacement, Midframe: passo 5, immagine 2 di 3 HP ProBook 640 Fan Replacement, Midframe: passo 5, immagine 3 di 3
    • Remove the eight rubber screw plugs from the bottom and the two rubber screw plugs from the sides of the laptop using a paperclip.
    • Remove the fourteen 6 mm screws from the bottom of the laptop and the two 6 mm screws from the sides using a T8 Torx screwdriver.
    • Remove the six 4 mm screws that secure the midframe using a T8 Torx screwdriver.
    • Some of the screws are held in place by springs and cannot be fully removed, but can still be loosened.
    Chiedi a FixBot
    Aggiungi Commento
  6. HP ProBook 640 Fan Replacement: passo 6, immagine 1 di 2 HP ProBook 640 Fan Replacement: passo 6, immagine 2 di 2
    • Remove the disk drive by gently pulling it out.
    • Remove the two 3 mm screws using a Phillips #1 screwdriver.
    • Only one screw is visible in the photo the second screw is located directly above it.
    Chiedi a FixBot
    Aggiungi Commento
  7. HP ProBook 640 Fan Replacement: passo 7, immagine 1 di 2 HP ProBook 640 Fan Replacement: passo 7, immagine 2 di 2
    • Gently pull up on the midframe, gripping it from the inside.
    • This may take a small amount of force. If it feels stuck, check for missed screws. Go back to the previous steps and make sure you have removed all necessary screws.
    Chiedi a FixBot
    Aggiungi Commento
  8. HP ProBook 640 Fan Replacement, Fan: passo 8, immagine 1 di 2 HP ProBook 640 Fan Replacement, Fan: passo 8, immagine 2 di 2
    • Loosen the two captive screws in the fan using a Phillips #1 screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  9. HP ProBook 640 Fan Replacement: passo 9, immagine 1 di 2 HP ProBook 640 Fan Replacement: passo 9, immagine 2 di 2
    • Carefully lift the fan and disconnect its cable from the motherboard.
    • Remove the fan from the laptop.
    • Avoid touching motherboard components directly to prevent static damage.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 11
Ultimi 30 giorni: 31
Tutti i Tempi: 250
