Salta al contenuto principale
HP EliteBook x360 1030 G3 Battery Replacement
Cosa ti serve
  1. HP EliteBook x360 1030 G3 Battery Replacement, Bottom Cover: passo 1, immagine 1 di 1
    • Be sure to power off and unplug your device before you begin your repair.
    • Close the laptop and flip it so that the screen is on the surface of the table and the back plate is facing you.
    • Remove the 3.3 mm screw near the top of the hinge using a T5 Torx screwdriver.
    • Remove the remaining four 7.3 mm screws using the same screwdriver.
  2. HP EliteBook x360 1030 G3 Battery Replacement: passo 2, immagine 1 di 1
    • Separate the bottom cover from the laptop, starting from the upper corner and working your way around the edge.
    • The plastic fastening may make cracking sounds when separating, but this is normal.
  3. HP EliteBook x360 1030 G3 Battery Replacement, Battery: passo 3, immagine 1 di 1
    • Remove the five 3.7 mm screws that are holding the battery in place using a Phillips #00 screwdriver.
    • Be sure to keep the screws organized because they will be reused for the next battery installation.
  4. HP EliteBook x360 1030 G3 Battery Replacement: passo 4, immagine 1 di 2 HP EliteBook x360 1030 G3 Battery Replacement: passo 4, immagine 2 di 2
    • Carefully pull the white plastic battery connector towards you until it is removed from the port.
    • Be sure not to pull using the wires; doing so may cause damage.
  5. HP EliteBook x360 1030 G3 Battery Replacement: passo 5, immagine 1 di 1
    • Gently lift the battery out of its place.
Conclusione
Altre 10 persone hanno completato questa guida.
Cal Poly, Team S2-G9, Maness Spring 2019 Membro di Cal Poly, Team S2-G9, Maness Spring 2019
CPSU-MANESS-S19S2G9
4 Membri
16 Guide realizzate
5 Commenti
Thanks, it is very useful.
Mohamed Wafi Aljunaedi - Replica
thats very nice
montrez damonei - Replica
Looks easy and do you know if the pc can work without battery, only with charger?
Sam Uel - Replica
Thank you. very useful.
mustapha ELABED - Replica
Very simple and precise with good warnings too
Roland Appiah - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 35
Ultimi 30 Giorni: 151
Tutti i Tempi: 13,272
