Salta al contenuto principale
HP 15-ay078nr Battery Replacement
  1. HP 15-ay078nr Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Orient the laptop so that the underside is facing up.
    • Rotate the device so that the CD slot is in the upper left corner.
  2. HP 15-ay078nr Battery Replacement: passo 2, immagine 1 di 2 HP 15-ay078nr Battery Replacement: passo 2, immagine 2 di 2
    • Put your fingers on the battery latch.
  3. HP 15-ay078nr Battery Replacement: passo 3, immagine 1 di 2 HP 15-ay078nr Battery Replacement: passo 3, immagine 2 di 2
    • Using your fingers, push each battery latch simultaneously towards the middle.
    • This releases the battery.
    • Remove the battery from the laptop.
Conclusione
After installing the replacement battery, connect the device to a power source. The battery will not have a prior charge.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Cameron Duffy
Membro da: 10/25/21
327 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 188
