Salta al contenuto principale
HMD Barbie Keypad Replacement
Cosa ti serve
  1. HMD Barbie Keypad Replacement, Battery: passo 1, immagine 1 di 3 HMD Barbie Keypad Replacement, Battery: passo 1, immagine 2 di 3 HMD Barbie Keypad Replacement, Battery: passo 1, immagine 3 di 3
    • Fully power off the phone.
    • Remove the backplate by gripping it around the edges and pulling away from the phone.
    Chiedi a FixBot
    Aggiungi Commento
  2. HMD Barbie Keypad Replacement: passo 2, immagine 1 di 3 HMD Barbie Keypad Replacement: passo 2, immagine 2 di 3 HMD Barbie Keypad Replacement: passo 2, immagine 3 di 3
    • Grip the battery from the top and pull away from the phone.
    • Ensure there is no swelling or damage to the battery. A swollen or damaged battery can be a fire hazard.
    Chiedi a FixBot
    Aggiungi Commento
  3. HMD Barbie Keypad Replacement, Inner Backplate: passo 3, immagine 1 di 1
    • Remove the six 5mm screws using the T5 Torx screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  4. HMD Barbie Keypad Replacement: passo 4, immagine 1 di 2 HMD Barbie Keypad Replacement: passo 4, immagine 2 di 2
    • Remove the backplate using an opening tool.
    • Find an opening on the phone that makes it easiest to remove the backplate. Any side of the phone will work.
    Chiedi a FixBot
    Aggiungi Commento
  5. HMD Barbie Keypad Replacement, Motherboard: passo 5, immagine 1 di 3 HMD Barbie Keypad Replacement, Motherboard: passo 5, immagine 2 di 3 HMD Barbie Keypad Replacement, Motherboard: passo 5, immagine 3 di 3
    • Use the opening tool to remove the clear plastic clip near the hinge of the phone securing the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  6. HMD Barbie Keypad Replacement: passo 6, immagine 1 di 3 HMD Barbie Keypad Replacement: passo 6, immagine 2 di 3 HMD Barbie Keypad Replacement: passo 6, immagine 3 di 3
    • The video ribbon is connected to the motherboard with a flat-topped, low profile connector. It is also secured with a piece of tape.
    • Use the tweezers to gently unstick the tape from the motherboard, leaving it stuck to the connector.
    • Use the tweezers to gently pull up on the connector until it disconnects from the motherboard.
    • Be gentle as you apply pressure on the tape and connector. These parts shouldn't take too much force to remove.
    Chiedi a FixBot
    Aggiungi Commento
  7. HMD Barbie Keypad Replacement: passo 7, immagine 1 di 3 HMD Barbie Keypad Replacement: passo 7, immagine 2 di 3 HMD Barbie Keypad Replacement: passo 7, immagine 3 di 3
    • Beginning at the corner near where the video ribbon is located, insert an opening pick between the green motherboard and the pink housing.
    • Slowly work your way around the motherboard until it loosens enough that you can use your fingers to remove it.
    Chiedi a FixBot
    Aggiungi Commento
  8. HMD Barbie Keypad Replacement, Keypad: passo 8, immagine 1 di 3 HMD Barbie Keypad Replacement, Keypad: passo 8, immagine 2 di 3 HMD Barbie Keypad Replacement, Keypad: passo 8, immagine 3 di 3
    • Push the keypad out of the outer casing from the front of the phone, outward.
    • You may now replace the keypad with a new one, inserting it where the old keypad was. Make sure to not obstruct any of the holes for screws with the keypad.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 28
Tutti i Tempi: 91
