Salta al contenuto principale
Grip Tape Application
Cosa ti serve
  1. Grip Tape Application, Grip Tape Application: passo 1, immagine 1 di 1
    • Peel off the paper backing from the sheet of grip tape.
    • Make sure you do not fold or wrinkle the grip tape.
    Chiedi a FixBot
    Aggiungi Commento
  2. Grip Tape Application: passo 2, immagine 1 di 1
    • Center the sheet of grip tape evenly over the top of the skateboard deck.
    Chiedi a FixBot
    Aggiungi Commento
  3. Grip Tape Application: passo 3, immagine 1 di 2 Grip Tape Application: passo 3, immagine 2 di 2
    • Starting from the very middle and moving outward, firmly press down on the grip tape while smoothing out any air bubbles that start to form.
    Chiedi a FixBot
    Aggiungi Commento
  4. Grip Tape Application: passo 4, immagine 1 di 2 Grip Tape Application: passo 4, immagine 2 di 2
    • Use a screwdriver to scrape along the edges of the skateboard. This will remove some of the grip around the edges making the trimming process easier on you and your equipment.
    • You can use the utility knife to cut a perpendicular line in the excess grip tape if it is resisting the screwdriver too much.
    Chiedi a FixBot
    Aggiungi Commento
  5. Grip Tape Application: passo 5, immagine 1 di 3 Grip Tape Application: passo 5, immagine 2 di 3 Grip Tape Application: passo 5, immagine 3 di 3
    • Use a utility knife to begin cutting around the edge of your skateboard to remove excess grip tape.
    • Angle your knife towards the inside of the skateboard to make it easier to cut a straight line.
    • Be careful when using the utility knife and always keep it pointed away from yourself and others.
    Chiedi a FixBot
    Aggiungi Commento
  6. Grip Tape Application: passo 6, immagine 1 di 1
    • Once you have removed all of the excess grip tape, you can use the scraps to sand the edges of your cut to smooth out any small inconsistencies.
    • Use caution when sanding as the grip tape can become heated.
    Chiedi a FixBot
    Aggiungi Commento
  7. Grip Tape Application: passo 7, immagine 1 di 1
    • If air bubbles persist, gently use a utility knife to poke a small hole in the grip tape at the center of the bubble and press out the air.
    Chiedi a FixBot
    Aggiungi Commento
  8. Grip Tape Application: passo 8, immagine 1 di 2 Grip Tape Application: passo 8, immagine 2 di 2
    • After you have finished applying your grip tape, you can use a small screwdriver to poke holes where your truck hardware will be installed.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
The next logical step in the assembly of a skateboard is to install skateboard trucks, please reference the Truck Installation guide.
Altre 4 persone hanno completato questa guida.
Cal Poly, Team 6-32, Regan Fall 2012 Membro di Cal Poly, Team 6-32, Regan Fall 2012
CPSU-REGAN-F12S6G32
5 Membri
6 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 4
Ultimi 30 giorni: 39
Tutti i Tempi: 8,518
