Salta al contenuto principale
Skateboard Trucks Replacement
Cosa ti serve
  1. Skateboard Trucks Replacement, Trucks: passo 1, immagine 1 di 2 Skateboard Trucks Replacement, Trucks: passo 1, immagine 2 di 2
    • Insert bolt hardware through the factory drilled holes from the top side of the skateboard.
    • If you have a riser and would like to install it, please reference the Wheel Bite Prevention guide.
  2. Skateboard Trucks Replacement: passo 2, immagine 1 di 1
    • Slide the truck onto the four protruding bolt hardware screws, while using your hand to prevent the screws from popping out the top of the skateboard.
  3. Skateboard Trucks Replacement: passo 3, immagine 1 di 1
    • Hand tighten the nut hardware onto all four bolts.
  4. Skateboard Trucks Replacement: passo 4, immagine 1 di 1
    • While holding the nuts on the bottom side of the skateboard in place with the 3/8" wrench, tighten the screws from the top side of the skateboard with a screwdriver. Tighten the screws in a diagonal pattern until the head of the screw sinks slightly into the grip tape.
    • Repeat steps 1 - 6 to install the second truck.
Conclusione
To uninstall your trucks, simply follow these steps in reverse order. To continue assembling your skateboard deck, see the Wheel Installation guide.
Altre 2 persone hanno completato questa guida.
Cameron Nye
Membro da: 10/03/12
79 Reputazione
1 Guida realizzata
Cal Poly, Team 6-32, Regan Fall 2012 Membro di Cal Poly, Team 6-32, Regan Fall 2012
CPSU-REGAN-F12S6G32
5 Membri
6 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 71
Tutti i Tempi: 13,796
