Salta al contenuto principale
GravityLight LED Replacement
Cosa ti serve
  1. GravityLight LED Replacement, Removing the Front Panel: passo 1, immagine 1 di 2 GravityLight LED Replacement, Removing the Front Panel: passo 1, immagine 2 di 2
    • Flip the GravityLight on its back and place it on a sturdy surface.
    • Unscrew the three 2cm Phillips #00 screws on the back of the GravityLight’s body.
    Chiedi a FixBot
    Aggiungi Commento
  2. GravityLight LED Replacement, Opening the Device Housing: passo 2, immagine 1 di 1
    • Some of the internal pieces may loosen or fall out during disassembly.
    • Firmly grasp both parts of the GravityLight body and pull them apart.
    Chiedi a FixBot
    Aggiungi Commento
  3. GravityLight LED Replacement, Removing the Back Panel Screws: passo 3, immagine 1 di 1
    • Place the back panel, the larger of the two pieces, on a sturdy surface with its back down.
    • Unscrew the two 2cm Phillips 00 screws on the inside of the back panel.
    Chiedi a FixBot
    Aggiungi Commento
  4. GravityLight LED Replacement, Removing the LED Housing: passo 4, immagine 1 di 2 GravityLight LED Replacement, Removing the LED Housing: passo 4, immagine 2 di 2
    • Hold the LED housing in your hand, but do not separate it too far otherwise you will tear the wires.
    • Lift the LED housing away from the back panel.
    Chiedi a FixBot
    Aggiungi Commento
  5. GravityLight LED Replacement, Remove the White Gear from the LED Housing: passo 5, immagine 1 di 2 GravityLight LED Replacement, Remove the White Gear from the LED Housing: passo 5, immagine 2 di 2
    • Grab the outside of the large, white gear in the LED housing and pull the gear out of the housing.
    Chiedi a FixBot
    Aggiungi Commento
  6. GravityLight LED Replacement, Position the LED Housing: passo 6, immagine 1 di 1
    • Set the LED housing flat on a sturdy surface so that the back of the LED and the wires are exposed.
    Chiedi a FixBot
    Aggiungi Commento
  7. GravityLight LED Replacement, Cut the Wires: passo 7, immagine 1 di 1
    • Place the GravityLight's back panel aside.
    • Use the Flush Wire Cutter to cut both the purple wire and the red wire that connect to the LED.
    Chiedi a FixBot
    Aggiungi Commento
  8. GravityLight LED Replacement, Bend the LED Leads: passo 8, immagine 1 di 1
    Strumento utilizzato in questo passaggio:
    • Take tweezers and bend the leads (the silver wires coming out of the bulb) so that the leads are straight.
    • The straight leads will make the LED easier to take out.
    Chiedi a FixBot
    Aggiungi Commento
  9. GravityLight LED Replacement, Remove the LED: passo 9, immagine 1 di 1
    • Flip the LED housing over.
    • Pull the LED out with tweezers.
    Chiedi a FixBot
    Aggiungi Commento
  10. GravityLight LED Replacement, Soldering the New LED: passo 10, immagine 1 di 1
    • For reassembly: Flip the LED housing back over.
    • Put the new LED in its spot. Solder the red wire and the purple wire back onto the new leads.
    • Make sure that you pair each wire to the correct lead. If the LED still does not light, switch the wires on the leads.
    • For information on how to solder look here: Come saldare e dissaldare componenti elettrici
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Cal Poly, Team 12-2, Forte Fall 2014 Membro di Cal Poly, Team 12-2, Forte Fall 2014
CPSU-FORTE-F14S12G2
5 Membri
7 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 4
Ultimi 30 giorni: 27
Tutti i Tempi: 1,006
