Salta al contenuto principale
Google Pixel 5 Screen Adhesive Installation
Cosa ti serve
  1. Google Pixel 5 Screen Adhesive Installation, Remove adhesive residue from the frame: passo 1, immagine 1 di 3 Google Pixel 5 Screen Adhesive Installation, Remove adhesive residue from the frame: passo 1, immagine 2 di 3 Google Pixel 5 Screen Adhesive Installation, Remove adhesive residue from the frame: passo 1, immagine 3 di 3
    Strumento utilizzato in questo passaggio:
    • Peel off as much adhesive as you can with a pair of tweezers.
    • Use a spudger to scrape away any lingering adhesive.
    • Don't use metal tools to scrape away adhesive as this will damage the frame.
    • For best results, clean the area underneath the removed adhesive with 90% or greater isopropyl alcohol to prep the surface for the new adhesive.
    Chiedi a FixBot
  2. Google Pixel 5 Screen Adhesive Installation, Remove adhesive residue from the screen: passo 2, immagine 1 di 3 Google Pixel 5 Screen Adhesive Installation, Remove adhesive residue from the screen: passo 2, immagine 2 di 3 Google Pixel 5 Screen Adhesive Installation, Remove adhesive residue from the screen: passo 2, immagine 3 di 3
    • Repeat the previous step for the screen adhesive.
    • Don't use metal tools to scrape away adhesive as this will damage the screen.
    • Don't use isopropyl alcohol near the front camera bracket as it will loosen its adhesive.
    Chiedi a FixBot
  3. Google Pixel 5 Screen Adhesive Installation, Align the adhesive: passo 3, immagine 1 di 2 Google Pixel 5 Screen Adhesive Installation, Align the adhesive: passo 3, immagine 2 di 2
    • Use the holes in the top right and bottom left corners of the frame to correctly align the adhesive:
    • The top right hole is circular
    • The bottom left hole is oblong
    Chiedi a FixBot
  4. Google Pixel 5 Screen Adhesive Installation, Prepare the adhesive: passo 4, immagine 1 di 1
    • Peel away the clear plastic lining to expose the frame side of the adhesive.
    Chiedi a FixBot
  5. Google Pixel 5 Screen Adhesive Installation, Apply the adhesive: passo 5, immagine 1 di 2 Google Pixel 5 Screen Adhesive Installation, Apply the adhesive: passo 5, immagine 2 di 2
    • Be very careful during this step! The adhesive is very sticky and can't be repositioned once it sticks. Misaligned adhesive can lead to an improper seal.
    • Lower the adhesive onto the frame.
    • Use the holes in the top right and bottom left corners to properly align the adhesive during installation.
    Chiedi a FixBot
  6. Google Pixel 5 Screen Adhesive Installation, Secure the adhesive to the frame: passo 6, immagine 1 di 2 Google Pixel 5 Screen Adhesive Installation, Secure the adhesive to the frame: passo 6, immagine 2 di 2
    • Use the flat end of a spudger or your fingernail to press down on the adhesive.
    • Slide along the perimeter to secure the adhesive to the frame.
    Chiedi a FixBot
  7. Google Pixel 5 Screen Adhesive Installation, Peel away the outer plastic lining: passo 7, immagine 1 di 2 Google Pixel 5 Screen Adhesive Installation, Peel away the outer plastic lining: passo 7, immagine 2 di 2
    • Use your fingers to grasp the blue plastic lining near the center and peel it away from the phone.
    • This should leave a thin perimeter of adhesive still covered by blue plastic lining.
    Chiedi a FixBot
  8. Google Pixel 5 Screen Adhesive Installation, Connect the screen: passo 8, immagine 1 di 2 Google Pixel 5 Screen Adhesive Installation, Connect the screen: passo 8, immagine 2 di 2
    Chiedi a FixBot
  9. Google Pixel 5 Screen Adhesive Installation, Peel away the remaining plastic lining: passo 9, immagine 1 di 2 Google Pixel 5 Screen Adhesive Installation, Peel away the remaining plastic lining: passo 9, immagine 2 di 2
    • Peel away the blue plastic lining to expose the perimeter adhesive.
    Chiedi a FixBot
  10. Google Pixel 5 Screen Adhesive Installation, Position the screen: passo 10, immagine 1 di 3 Google Pixel 5 Screen Adhesive Installation, Position the screen: passo 10, immagine 2 di 3 Google Pixel 5 Screen Adhesive Installation, Position the screen: passo 10, immagine 3 di 3
    • Position the screen so it lays on the frame.
    Chiedi a FixBot
  11. Google Pixel 5 Screen Adhesive Installation, Press down the screen corners: passo 11, immagine 1 di 2 Google Pixel 5 Screen Adhesive Installation, Press down the screen corners: passo 11, immagine 2 di 2
    • Press down the corners of the screen to secure them to the frame.
    Chiedi a FixBot
  12. Google Pixel 5 Screen Adhesive Installation, Secure the screen to the frame: passo 12, immagine 1 di 3 Google Pixel 5 Screen Adhesive Installation, Secure the screen to the frame: passo 12, immagine 2 di 3 Google Pixel 5 Screen Adhesive Installation, Secure the screen to the frame: passo 12, immagine 3 di 3
    • Press down on the edges of the screen.
    • Slide along the perimeter to secure it to the frame.
    • You can heat the perimeter of the screen to soften the adhesive and help it bond more securely.
    Chiedi a FixBot
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Pixel 5 Answers community for help.
Altre 34 persone hanno completato questa guida.
Chayton Ritter
Membro da: 08/21/20
26.689 Reputazione
105 guide realizzate
Guide Team Membro di Guide Team
Staff
10 Membri
17.792 guide realizzate
1Commento della guida
Vielen Dank für die ausführliche und hilfreiche Anleitung. Hat alles geklappt. Leider hatte ich die Schutzfolie über der Frontkamera übersehen. Die funktioniert jetzt nicht mehr. Das sollte noch in der Anleitung ergänzt werden.
Simon - Rispondi Condividi
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 37
Ultimi 30 Giorni: 239
Tutti i Tempi: 13,210
