Salta al contenuto principale
Google Pixel 3 XL Back Cover Replacement
Cosa ti serve
  1. Google Pixel 3 XL Back Cover Replacement, Heat the edge of the back cover: passo 1, immagine 1 di 3 Google Pixel 3 XL Back Cover Replacement, Heat the edge of the back cover: passo 1, immagine 2 di 3 Google Pixel 3 XL Back Cover Replacement, Heat the edge of the back cover: passo 1, immagine 3 di 3
    • Heat an iOpener and apply it to the right edge of the back cover for a minute.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    • While you wait, note the following areas on the back cover:
    • Strong adhesive—there are large patches of adhesive near the bottom of the phone.
    • Fingerprint sensor cable—be careful not to slice through the cable as you pry
  2. Google Pixel 3 XL Back Cover Replacement, Create a gap under the back cover: passo 2, immagine 1 di 3 Google Pixel 3 XL Back Cover Replacement, Create a gap under the back cover: passo 2, immagine 2 di 3 Google Pixel 3 XL Back Cover Replacement, Create a gap under the back cover: passo 2, immagine 3 di 3
    • Apply a suction cup to the heated edge of the back cover, as close to the edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap.
    • Depending on the age of your phone, this may be difficult. If you are having trouble, apply heat to the edge and try again.
    • Insert the point of an opening pick into the gap.
  3. Google Pixel 3 XL Back Cover Replacement, Loosen the right edge adhesives: passo 3, immagine 1 di 3 Google Pixel 3 XL Back Cover Replacement, Loosen the right edge adhesives: passo 3, immagine 2 di 3 Google Pixel 3 XL Back Cover Replacement, Loosen the right edge adhesives: passo 3, immagine 3 di 3
    • Slide the opening pick along the right edge to slice through the adhesive.
    • The adhesive gums up and becomes hard to slice once it cools. If that happens, re-apply heat to the edge to make slicing easier.
    • Once you have sliced through the edge, leave an opening pick in the seam to prevent the adhesive from re-sealing.
  4. Google Pixel 3 XL Back Cover Replacement, Heat the bottom edge of the back cover: passo 4, immagine 1 di 1
    • Apply a heated iOpener to the bottom of the back cover for a minute.
  5. Google Pixel 3 XL Back Cover Replacement, Slice through the bottom adhesives: passo 5, immagine 1 di 3 Google Pixel 3 XL Back Cover Replacement, Slice through the bottom adhesives: passo 5, immagine 2 di 3 Google Pixel 3 XL Back Cover Replacement, Slice through the bottom adhesives: passo 5, immagine 3 di 3
    • Use an opening pick to slice around the bottom right corner and continue along the bottom edge of the phone.
    • Work slowly as you slice around the corner to prevent the panel from cracking. If the slicing becomes hard, re-apply heat.
    • Leave a pick in the edge to prevent the adhesive from re-sealing.
  6. Google Pixel 3 XL Back Cover Replacement, Slice through the remaining edges: passo 6, immagine 1 di 3 Google Pixel 3 XL Back Cover Replacement, Slice through the remaining edges: passo 6, immagine 2 di 3 Google Pixel 3 XL Back Cover Replacement, Slice through the remaining edges: passo 6, immagine 3 di 3
    • Continue heating and slicing the remaining edges of the phone.
    • Be careful as you slice along the left edge of the phone. If your pick feels like it's stuck near the top, you may have snagged the fingerprint sensor. Retract the pick out of the seam slightly and try again.
    • Be sure to cut through the thick portions of adhesive near the bottom and right edge of the phone.
  7. Google Pixel 3 XL Back Cover Replacement, Slice through the leftover adhesive: passo 7, immagine 1 di 1
    • Gently pry up the right edge of the back cover.
    • Use an opening pick to slice through any remaining adhesive along the edges.
  8. Google Pixel 3 XL Back Cover Replacement, Swing open the back cover: passo 8, immagine 1 di 3 Google Pixel 3 XL Back Cover Replacement, Swing open the back cover: passo 8, immagine 2 di 3 Google Pixel 3 XL Back Cover Replacement, Swing open the back cover: passo 8, immagine 3 di 3
    • Swing the right edge of the back cover upwards and rest the flipped panel along the left side of the phone.
    • Be sure to maintain slack on the fingerprint sensor cable and prevent it from being pinched.
    • During reassembly, this is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • During reassembly, follow this guide to install custom-cut adhesives for your back cover.
    • If you replaced the fingerprint sensor, you'll need to use this software tool to make the phone recognize the new sensor.
  9. Google Pixel 3 XL Back Cover Replacement, Remove the fingerprint sensor tape: passo 9, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • User tweezers to carefully peel up the yellow tape over the fingerprint sensor connector.
  10. Google Pixel 3 XL Back Cover Replacement, Disconnect the fingerprint sensor: passo 10, immagine 1 di 3 Google Pixel 3 XL Back Cover Replacement, Disconnect the fingerprint sensor: passo 10, immagine 2 di 3 Google Pixel 3 XL Back Cover Replacement, Disconnect the fingerprint sensor: passo 10, immagine 3 di 3
    • Use the point of a spudger to carefully flip up the black lock bar on the fingerprint sensor's ZIF socket.
    • Grasp the cable's tab with your fingers or tweezers and gently walk the flex cable out of the socket.
    • To prevent shorting, be careful not to touch the metal contacts on the flex cable with your tweezers.
  11. Google Pixel 3 XL Back Cover Replacement, Remove the back cover: passo 11, immagine 1 di 1
    • Remove the back cover.
    • Follow this guide to correctly apply new back cover adhesive.
  12. Google Pixel 3 XL Back Cover Replacement, Heat the fingerprint sensor: passo 12, immagine 1 di 1
    • Apply a heated iOpener over the fingerprint sensor for a minute.
  13. Google Pixel 3 XL Back Cover Replacement, Pry up the fingerprint sensor: passo 13, immagine 1 di 3 Google Pixel 3 XL Back Cover Replacement, Pry up the fingerprint sensor: passo 13, immagine 2 di 3 Google Pixel 3 XL Back Cover Replacement, Pry up the fingerprint sensor: passo 13, immagine 3 di 3
    • Insert the edge of an opening tool underneath the square portion of the fingerprint sensor and slowly pry up to loosen the sensor.
    • Continue prying around the perimeter of the fingerprint sensor until it is loosened.
  14. Google Pixel 3 XL Back Cover Replacement, Loosen the fingerprint sensor: passo 14, immagine 1 di 1
    • From the outer side of the back cover, use your finger to push the fingerprint sensor out of its cutout.
  15. Google Pixel 3 XL Back Cover Replacement, Remove the fingerprint sensor: passo 15, immagine 1 di 1
    Tesa 61395 Tape
    $8.95
    • Remove the fingerprint sensor.
    • If you are transferring the fingerprint sensor to a new back cover, use some double-sided tape such as Tesa tape to affix it to the new panel.
  16. Google Pixel 3 XL Back Cover Replacement, Remove the flash diffuser: passo 16, immagine 1 di 1
    • Insert the edge of an opening tool underneath the plastic flash diffuser and slowly pry up to loosen the diffuser.
    • Remove the diffuser.
  17. Google Pixel 3 XL Back Cover Replacement, Remove the rear camera bracket: passo 17, immagine 1 di 1
    • Insert the edge of an opening tool underneath the camera bracket and pry up to loosen it.
    • Remove and transfer the camera bracket to your replacement part.
    • Compare your new replacement back cover to the original part. You may need to transfer additional components or remove adhesive backings from the new part before installing.
Conclusione
Altre 11 persone hanno completato questa guida.
Arthur Shi
Membro da: 01/03/18
334.361 Reputazione
847 Guide realizzate
iFixit Membro di iFixit
Staff
123 Membri
25.548 Guide realizzate
11Commenti sulla guida
What’s the flat pice that surrounds the fingerprint sensor? It appears to have two pieces that connect with a terminal on the logic board.
Grant Pauli - Replica Condividi
Is it the NFC reader?
Grant Pauli - Condividi
Correct! That is the NFC coil.
Arthur Shi - Condividi
I successfully installed the screen but accidentally broke off the gold tab sticking up from the mother board shield. It can be seen on the picture of step 11 next to the NFC connectors. Do you know what this is for and how it will affect the function of the phone?
Sal Arias - Replica Condividi
Hi Sal!
That tab looks to be a grounding clip, which would normally touch the fingerprint sensor bracket. I don’t think it is vital for daily function.
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 42
Ultimi 30 Giorni: 141
Tutti i Tempi: 17,238
