Salta al contenuto principale
Garmin Vivoactive Display Unit Replacement
Cosa ti serve
  1. Garmin Vivoactive Display Unit Replacement, Wristband: passo 1, immagine 1 di 1
    • Hold the the metal screwdriver, with a T5 Torx bit, in your dominant hand.
    • Hold the rubber screwdriver, with a Hex T6 Torx bit, in your other hand.
    • While holding the rubber screwdriver in place, simultaneously unscrew the pin (counterclockwise) with the metal screwdriver in your dominant hand.
    Chiedi a FixBot
    Aggiungi Commento
  2. Garmin Vivoactive Display Unit Replacement: passo 2, immagine 1 di 2 Garmin Vivoactive Display Unit Replacement: passo 2, immagine 2 di 2
    • Once the 1mm screw is removed, reinsert the metal screwdriver in that same hole.
    • Gently push the strap's pin out. It will begin to protrude from the other end.
    • Use your fingers to grab the exposed pin and slide it free. The strap should now be disconnected from the device.
    Chiedi a FixBot
    Aggiungi Commento
  3. Garmin Vivoactive Display Unit Replacement, Display Unit: passo 3, immagine 1 di 1
    • Place a heated iOpener over the display to loosen the adhesive.
    • After about a minute, the iOpener may be removed.
    • For more in depth instructions on using the iOpener, refer to the iOpener guide.
    Chiedi a FixBot
    Aggiungi Commento
  4. Garmin Vivoactive Display Unit Replacement: passo 4, immagine 1 di 2 Garmin Vivoactive Display Unit Replacement: passo 4, immagine 2 di 2
    • Place the blue plastic opening tool in-between the screen and plastic casing of the watch and slowly pry up one side of the screen.
    Chiedi a FixBot
    Aggiungi Commento
  5. Garmin Vivoactive Display Unit Replacement: passo 5, immagine 1 di 1
    • Once the first side has come free, wedge the blue pick in between the screen and watch unit on that side.
    • Complete one pass around the perimeter of the screen to break the adhesive bond on all four sides.
    • Insert it a minimal distance to avoid damaging internal components.
    Chiedi a FixBot
    Aggiungi Commento
  6. Garmin Vivoactive Display Unit Replacement: passo 6, immagine 1 di 1
    • Use the blue plastic opening tool to pry up the side of the glass. Raise it to a point where your fingernail can fit in the gap.
    • Do the same on the opposite side of the device until you have a good grip of the screen.
    Chiedi a FixBot
    Aggiungi Commento
  7. Garmin Vivoactive Display Unit Replacement: passo 7, immagine 1 di 1
    • Obtain a careful grip of the screen from two of its sides.
    • Slowly lift the screen off of the case. Separate it just enough so as not to damage the connection to the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  8. Garmin Vivoactive Display Unit Replacement: passo 8, immagine 1 di 1
    • Detach the orange tab that connects the screen to the motherboard with a gentle uplift using a plastic opening tool.
    • Upon completing this step, the screen should be free from the rest of the device.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 16 persone hanno completato questa guida.
Cal Poly, Team 1-21, Maness Fall 2015 Membro di Cal Poly, Team 1-21, Maness Fall 2015
CPSU-MANESS-F15S1G21
4 Membri
17 guide realizzate
40Commenti sulla guida
Does anyone knows where can I buy a vivoactive display?
dragomariano - Rispondi Condividi
I need one vivoactive display too. If I can find how to find, I'll share it here.
erol - Rispondi Condividi
Did anyone ever find a location where you can order a replacement screen?
Dylan
dylanreynolds - Rispondi Condividi
Any links found for replacement screen?
dskggray - Rispondi Condividi
I've called Garmin support service but they said that displays units are not for sale from their side, only entire watch can be sold. I find it quite strange for not saying stupid because it's normal that using a watch displays can have a problem or that can be broken and easily fixed by replace them.
Being that said, if someone finds an alternative please share it, thanks
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 24
Ultimi 30 giorni: 130
Tutti i Tempi: 105,231
