Salta al contenuto principale
GameSir Cyclone 2 Battery Replacement
Cosa ti serve
  1. GameSir Cyclone 2 Battery Replacement, Face Plate: passo 1, immagine 1 di 3 GameSir Cyclone 2 Battery Replacement, Face Plate: passo 1, immagine 2 di 3 GameSir Cyclone 2 Battery Replacement, Face Plate: passo 1, immagine 3 di 3
    • Flip the controller around so the back part is facing you.
    • Use a T6 Torx screwdriver to remove seven screws from the back of the controller.
    • One of the screws is hidden under the sticker. Use a pair of tweezers to lift the sticker and reveal the screw.
    Chiedi a FixBot
    Aggiungi Commento
  2. GameSir Cyclone 2 Battery Replacement: passo 2, immagine 1 di 1
    • The screws holding the face plate are of two different lengths:
    • The two longer screws belong to the two top screw sockets on the controller.
    • The five shorter screws belong in the five bottom screw sockets, two per handle, and on in the center of on the controller.
    Chiedi a FixBot
    Aggiungi Commento
  3. GameSir Cyclone 2 Battery Replacement: passo 3, immagine 1 di 2 GameSir Cyclone 2 Battery Replacement: passo 3, immagine 2 di 2
    • Face the controller toward you.
    • Gently lift the face plate off the controller.
    • The d-pad and action buttons will become loose once the face plate is lifted.
    Chiedi a FixBot
    Aggiungi Commento
  4. GameSir Cyclone 2 Battery Replacement, Joystick Covers: passo 4, immagine 1 di 3 GameSir Cyclone 2 Battery Replacement, Joystick Covers: passo 4, immagine 2 di 3 GameSir Cyclone 2 Battery Replacement, Joystick Covers: passo 4, immagine 3 di 3
    • Pull both joystick covers straight up to remove them from the controller.
    Chiedi a FixBot
    Aggiungi Commento
  5. GameSir Cyclone 2 Battery Replacement, Left and Right Bumpers and Triggers: passo 5, immagine 1 di 1
    • Note the bumpers and triggers on the controller.
    Chiedi a FixBot
    Aggiungi Commento
  6. GameSir Cyclone 2 Battery Replacement: passo 6, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove two screws on either side of the power button.
    • Remove the assembly that includes the power button and the top bumper buttons.
    Chiedi a FixBot
    Aggiungi Commento
  7. GameSir Cyclone 2 Battery Replacement: passo 7, immagine 1 di 1
    • Remove the bumpers and triggers from the controller.
    Chiedi a FixBot
    Aggiungi Commento
  8. GameSir Cyclone 2 Battery Replacement, LED: passo 8, immagine 1 di 1
    • Locate the two black boxes towards the bottom of the controller.
    • Remove these two boxes by pulling them away from the controller. They should snap right off.
    Chiedi a FixBot
    Aggiungi Commento
  9. GameSir Cyclone 2 Battery Replacement: passo 9, immagine 1 di 1
    • Locate the LED diffusers on either side of the controller face. They are clear, cylindrical strips that help spread light from the LED beneath the black boxes removed in the previous step.
    • Lift the upper ends of each LED diffuser and remove them.
    Chiedi a FixBot
    Aggiungi Commento
  10. GameSir Cyclone 2 Battery Replacement, Battery: passo 10, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove the four screws that secure the LED diffuser tracks.
    • Remove the LED diffuser tracks.
    Chiedi a FixBot
    Aggiungi Commento
  11. GameSir Cyclone 2 Battery Replacement: passo 11, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove the single screw in the center of the motherboard.
    • Remove the motherboard from the controller case.
    Chiedi a FixBot
    Aggiungi Commento
  12. GameSir Cyclone 2 Battery Replacement: passo 12, immagine 1 di 2 GameSir Cyclone 2 Battery Replacement: passo 12, immagine 2 di 2
    • Disconnect the battery connector from the socket on the motherboard.
    • Remove the battery.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
JasmineM
Membro da: 10/14/25
373 Reputazione
4 guide realizzate
UMass Dartmouth, Team 2-6, Bowman Fall 2025 Membro di UMass Dartmouth, Team 2-6, Bowman Fall 2025
UMASSD-BOWMAN-F25S2G6
4 Membri
7 guide realizzate
2Commenti sulla guida
Which battery is used there. I mean the specs so I can buy it.
Davi Ribeiro - Rispondi Condividi
Hi @daviribeiro, we don't have the specific battery details, but it uses a 860mAh rechargeable Lithium-ion battery.
Sarah Westberg - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 10
Ultimi 7 giorni: 76
Ultimi 30 giorni: 263
Tutti i Tempi: 1,546
