Salta al contenuto principale
Game Boy Color Screen Cover Replacement
Cosa ti serve
  1. Game Boy Color Screen Cover Replacement, Battery: passo 1, immagine 1 di 2 Game Boy Color Screen Cover Replacement, Battery: passo 1, immagine 2 di 2
    • Locate the battery compartment on the back of the Game Boy Color.
    • Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
    Chiedi a FixBot
    Aggiungi Commento
  2. Game Boy Color Screen Cover Replacement: passo 2, immagine 1 di 1
    • Remove the batteries from the battery compartment.
    Chiedi a FixBot
    Aggiungi Commento
  3. Game Boy Color Screen Cover Replacement, Screen Cover: passo 3, immagine 1 di 1
    • Carefully slide a razor blade under one of the corners of the screen cover.
    Chiedi a FixBot
    Aggiungi Commento
  4. Game Boy Color Screen Cover Replacement: passo 4, immagine 1 di 1
    • Carefully lift up on the corner of the screen until you can grab the corner with your fingers.
    • Continue gently pulling up on the cover until it is fully removed.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 27 persone hanno completato questa guida.
Cal Poly, Team 19-47, Regan Winter 2013 Membro di Cal Poly, Team 19-47, Regan Winter 2013
CPSU-REGAN-W13S19G47
4 Membri
61 guide realizzate
4Commenti sulla guida
bro, you mustn't to dismount the console to only remove the old lend
sdfsafas - Rispondi Condividi
You only need step 7 and 8.
h027299c - Rispondi Condividi
An alternative method is to in step 7 insert a small screwdriver into the hole in the front shell where the power light goes through and push off the screen enough to pry it off with your hands. Thereby avoiding this razor-near-the-screen business. You will also most likely need some alcohol (or similar) to loosen the residue leftover from the old screen.
Nick G - Rispondi Condividi
Yes that's true! I've seen repair videos where they do it the way you mentioned, much less of a headache
David Hannum - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 27
Ultimi 30 giorni: 150
Tutti i Tempi: 26,475
