Salta al contenuto principale
Game Boy Color Power LED Replacement
Cosa ti serve
  1. Game Boy Color Power LED Replacement, Battery: passo 1, immagine 1 di 2 Game Boy Color Power LED Replacement, Battery: passo 1, immagine 2 di 2
    • Locate the battery compartment on the back of the Game Boy Color.
    • Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
    Chiedi a FixBot
    Aggiungi Commento
  2. Game Boy Color Power LED Replacement: passo 2, immagine 1 di 1
    • Remove the batteries from the battery compartment.
    Chiedi a FixBot
    Aggiungi Commento
  3. Game Boy Color Power LED Replacement, Back Housing: passo 3, immagine 1 di 1
    • Using a Y1 screwdriver, remove the six screws on the back of the device as pictured. The bottom two screws are located inside of the battery compartment.
    Chiedi a FixBot
    Aggiungi Commento
  4. Game Boy Color Power LED Replacement: passo 4, immagine 1 di 2 Game Boy Color Power LED Replacement: passo 4, immagine 2 di 2
    • Gently lift and separate the back housing from the rest of the device. Now you've got the back housing out!
    Chiedi a FixBot
    Aggiungi Commento
  5. Game Boy Color Power LED Replacement, Motherboard: passo 5, immagine 1 di 2 Game Boy Color Power LED Replacement, Motherboard: passo 5, immagine 2 di 2
    • Using the Phillips #1 screwdriver, remove the 3 screws shown in the picture.
    Chiedi a FixBot
    Aggiungi Commento
  6. Game Boy Color Power LED Replacement: passo 6, immagine 1 di 1
    • Gently lift the motherboard from the front housing.
    Chiedi a FixBot
    Aggiungi Commento
  7. Game Boy Color Power LED Replacement, Power LED: passo 7, immagine 1 di 2 Game Boy Color Power LED Replacement, Power LED: passo 7, immagine 2 di 2
    Chiedi a FixBot
    Aggiungi Commento
  8. Game Boy Color Power LED Replacement: passo 8, immagine 1 di 1
    • Insert new LED into the circuit board.
    • Make sure that the LED is in the correct orientation. The longer leg of the LED is the positive end, while the shorter leg is the negative end.
    • The positive lead should go through the hole closest to the edge of the circuit board.
    Chiedi a FixBot
    Aggiungi Commento
  9. Game Boy Color Power LED Replacement: passo 9, immagine 1 di 1
    • Solder the leads of the new LED to the circuit board.
    Chiedi a FixBot
    Aggiungi Commento
  10. Game Boy Color Power LED Replacement: passo 10, immagine 1 di 1
    • Cut the excess ends of the LED legs using the wire cutters.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 8 persone hanno completato questa guida.
Alex Wu
Membro da: 01/11/13
1.768 Reputazione
2 guide realizzate
Cal Poly, Team 19-47, Regan Winter 2013 Membro di Cal Poly, Team 19-47, Regan Winter 2013
CPSU-REGAN-W13S19G47
4 Membri
61 guide realizzate
6Commenti sulla guida
what is the brass color looking thing under the soldering iron in step 7?
Soul Divide - Rispondi Condividi
That's called 'Desoldering Braid', it sucks up solder like a wick
John Smith - Rispondi Condividi
and what kind of LED are you using to replace?
This was great! Exactly what I needed with this. My GBC is looking good as new now!
Erick - Rispondi Condividi
Bw sure to research what LED colors work best. You often need to remove a resistor adjacent to the diode to allow for the colors white/blue/purple.
Evan Wilgosh - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 10
Ultimi 7 giorni: 32
Ultimi 30 giorni: 135
Tutti i Tempi: 21,214
