Salta al contenuto principale
GI Node Installation Guide
Cosa ti serve
  1. GI Node Installation Guide, Select install location: passo 1, immagine 1 di 1
    • Locate a spot in the middle of the rain garden where the soil is bear/free from plants.
    • We need to install in the middle of the rain garden to ensure quality data.
    Chiedi a FixBot
    Aggiungi Commento
  2. GI Node Installation Guide, Auger hole for node: passo 2, immagine 1 di 2 GI Node Installation Guide, Auger hole for node: passo 2, immagine 2 di 2
    • At the selected location, use a post hole digger to make a hole for the node.
    • Take your time so as to not disturb the soil too much.
    • Use a tape measure to make sure the hole is 3 feet deep.
    • The soil removed from the hole will fill roughly 2 buckets
    • Fill the first bucket with topsoil
    • When the soil begins to look like clay, switch to filling the second bucket
    Chiedi a FixBot
    Aggiungi Commento
  3. GI Node Installation Guide, Install GI node: passo 3, immagine 1 di 2 GI Node Installation Guide, Install GI node: passo 3, immagine 2 di 2
    • Set the GI node into the 3 ft hole.
    • Do your best to make sure it is straight in the ground.
    • Pack the topsoil from the first bucket around the node to make sure it is secure in place. You shouldn't need to use any soil from the second bucket
    • If the surrounding plants are too tall, shading the solar panel, use the shears to trim the plants.
    Chiedi a FixBot
    Aggiungi Commento
    • Fill out the deployment form on AirTable.
    • Once installed, confirm the GI node is reporting to the internet by going to its designated website.
    Chiedi a FixBot
    Aggiungi Commento
Linea Traguardo
Brooke Mason
Membro da: 05/29/19
2.958 Reputazione
17 guide realizzate
Open-Storm Membro di Open-Storm
Community
14 Membri
45 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 5
Ultimi 30 giorni: 27
Tutti i Tempi: 507
