Salta al contenuto principale
Framework Laptop 12 Memory Module Replacement
Cosa ti serve
    1. Framework Laptop 12 Memory Module Replacement, Power down your laptop: passo 1, immagine 1 di 3 Framework Laptop 12 Memory Module Replacement, Power down your laptop: passo 1, immagine 2 di 3 Framework Laptop 12 Memory Module Replacement, Power down your laptop: passo 1, immagine 3 di 3
      • Before you begin repairs, unplug your laptop and shut it down from the operating system. This ensures that the laptop isn't in standby/suspend mode.
      • The indicator LEDs along the edges should be unlit. The laptop should be silent.
      • If you accidentally turn on the laptop during repair, hold the power button down for 10 seconds to shut it down.
      • Make sure your Framework Screwdriver has the T5 Torx bit (labeled as T-5) facing outwards. If it's not, pull the bit out and flip it.
      Chiedi a FixBot
      Aggiungi Commento
    1. Framework Laptop 12 Memory Module Replacement, Set your laptop down: passo 2, immagine 1 di 1
      • Set your Framework Laptop face-down on a clean work surface.
      Chiedi a FixBot
      Aggiungi Commento
    2. Framework Laptop 12 Memory Module Replacement, Loosen the bottom screws: passo 3, immagine 1 di 2 Framework Laptop 12 Memory Module Replacement, Loosen the bottom screws: passo 3, immagine 2 di 2
      • Use your Framework Screwdriver to fully loosen the eight captive T5 Torx screws on the bottom of your laptop.
      • Most screws in your Framework Laptop (including these) are captive—they're designed to stay in place after you loosen them.
      Chiedi a FixBot
      Aggiungi Commento
    3. Framework Laptop 12 Memory Module Replacement, Flip your laptop over: passo 4, immagine 1 di 1
      • Flip your laptop over so it's face-up on your work surface.
      Chiedi a FixBot
      Aggiungi Commento
    4. Framework Laptop 12 Memory Module Replacement, Open your laptop: passo 5, immagine 1 di 2 Framework Laptop 12 Memory Module Replacement, Open your laptop: passo 5, immagine 2 di 2
      • Open the laptop lid so that both the screen and the base lie flat on your work surface.
      Chiedi a FixBot
      Aggiungi Commento
    5. Framework Laptop 12 Memory Module Replacement, Remove the Input Cover: passo 6, immagine 1 di 3 Framework Laptop 12 Memory Module Replacement, Remove the Input Cover: passo 6, immagine 2 di 3 Framework Laptop 12 Memory Module Replacement, Remove the Input Cover: passo 6, immagine 3 di 3
      • Use your fingers to grip the Input Cover in the hinge cutouts.
      • Lift upwards to swing the Input Cover up from the base of the laptop.
      • Magnets hold the Input Cover down, so you'll feel some resistance. If it feels stuck, check that you've fully loosened all the screws on the bottom of your laptop.
      • Remove the Input Cover.
      Chiedi a FixBot
      Aggiungi Commento
    1. Framework Laptop 12 Memory Module Replacement, Open the memory flap: passo 7, immagine 1 di 2 Framework Laptop 12 Memory Module Replacement, Open the memory flap: passo 7, immagine 2 di 2
      • Use your fingers to flip open the memory flap.
      Chiedi a FixBot
      Aggiungi Commento
    2. Framework Laptop 12 Memory Module Replacement, Remove the memory module: passo 8, immagine 1 di 2 Framework Laptop 12 Memory Module Replacement, Remove the memory module: passo 8, immagine 2 di 2
      • Use your fingers to spread the clips on both sides of the memory module apart to unclip the memory.
      • The memory module will pop up to an angle when it's unclipped.
      Chiedi a FixBot
      Aggiungi Commento
    3. Framework Laptop 12 Memory Module Replacement: passo 9, immagine 1 di 2 Framework Laptop 12 Memory Module Replacement: passo 9, immagine 2 di 2
      • Use your fingers to grab the memory module by its edges.
      • Slide the memory module out of its socket and remove it.
      Chiedi a FixBot
      Aggiungi Commento
    1. Framework Laptop 12 Memory Module Replacement, Disassembly complete: passo 10, immagine 1 di 1
      • Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Laptop.
      Chiedi a FixBot
      Aggiungi Commento
    1. Framework Laptop 12 Memory Module Replacement, Install the memory module: passo 11, immagine 1 di 3 Framework Laptop 12 Memory Module Replacement, Install the memory module: passo 11, immagine 2 di 3 Framework Laptop 12 Memory Module Replacement, Install the memory module: passo 11, immagine 3 di 3
      • Hold the memory module by its edges. Don't touch the gold contacts with your fingers. If you do, wipe the contacts with a clean, lint-free cloth to remove any finger oils.
      • Orient the module with the label facing down and align the gold contacts with the socket.
      • Insert the contact edge into the socket at a shallow angle. The gold contacts should mostly be covered by the socket.
      • Press the edges of the memory module down until the side clips lock it in place.
      Chiedi a FixBot
      Aggiungi Commento
    2. Framework Laptop 12 Memory Module Replacement: passo 12, immagine 1 di 2 Framework Laptop 12 Memory Module Replacement: passo 12, immagine 2 di 2
      • Flip the memory flap back over the memory module.
      Chiedi a FixBot
      Aggiungi Commento
    1. Framework Laptop 12 Memory Module Replacement, Install the Input Cover: passo 13, immagine 1 di 3 Framework Laptop 12 Memory Module Replacement, Install the Input Cover: passo 13, immagine 2 di 3 Framework Laptop 12 Memory Module Replacement, Install the Input Cover: passo 13, immagine 3 di 3
      • Angle the bottom edge of the Input Cover towards the base of the laptop.
      • Align and insert the bottom edge of the Input Cover into the base of the laptop.
      • Make sure the slots along the bottom edge of the Input Cover slide into the tabs in the base.
      • Lower the Input Cover's top edge onto the laptop until the magnets snap it in place.
      • Make sure the Input Cover sits neatly within the laptop frame and no corners are popping up.
      Chiedi a FixBot
      Aggiungi Commento
    2. Framework Laptop 12 Memory Module Replacement, Close and flip your laptop: passo 14, immagine 1 di 2 Framework Laptop 12 Memory Module Replacement, Close and flip your laptop: passo 14, immagine 2 di 2
      • Close the laptop lid.
      • Flip your laptop face-down on a clean work surface.
      Chiedi a FixBot
      Aggiungi Commento
    3. Framework Laptop 12 Memory Module Replacement, Tighten the bottom screws: passo 15, immagine 1 di 2 Framework Laptop 12 Memory Module Replacement, Tighten the bottom screws: passo 15, immagine 2 di 2
      • Use your Framework Screwdriver to tighten the eight captive T5 Torx screws on the bottom of your laptop.
      • Tighten the screws until they're snug. Don't over-tighten them, or you may strip the screws.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
You finished fixing your Framework Laptop!
After installing new memory, the laptop will take longer to start up for the first time, and the screen will turn on slower. This is normal—the system is performing memory training.
If you need help, contact Framework support.
Altre 2 persone hanno completato questa guida.
Arthur Shi
Membro da: 01/03/18
346.192 Reputazione
921 guide realizzate
Guide Team Membro di Guide Team
Staff
10 Membri
51.739 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 10
Ultimi 30 giorni: 58
Tutti i Tempi: 877
