Salta al contenuto principale
Flydigi Apex 4 Trigger Assembly Replacement
Cosa ti serve
  1. Flydigi Apex 4 Trigger Assembly Replacement, Trigger Assembly: passo 1, immagine 1 di 3 Flydigi Apex 4 Trigger Assembly Replacement, Trigger Assembly: passo 1, immagine 2 di 3 Flydigi Apex 4 Trigger Assembly Replacement, Trigger Assembly: passo 1, immagine 3 di 3
    • Ensure the controller is fully powered off before beginning.
    • Disconnect the USB-C cable if the controller is plugged in.
    • Remove any wireless adapter or dongle connected to your device.
    • Never work on the controller while it is powered on or charging. Doing so may damage internal components or cause injury.
    Chiedi a FixBot
    Aggiungi Commento
  2. Flydigi Apex 4 Trigger Assembly Replacement: passo 2, immagine 1 di 3 Flydigi Apex 4 Trigger Assembly Replacement: passo 2, immagine 2 di 3 Flydigi Apex 4 Trigger Assembly Replacement: passo 2, immagine 3 di 3
    • Remove the button caps and the magnetic faceplate of the controller.
    • It should come off with a tug.
    • Use a Phillips #00 screwdriver to remove the four screws securing the front of the controller to the frame.
    • Some screws may be hidden under grip pads or stickers. Gently peel these back if necessary.
    Chiedi a FixBot
    Aggiungi Commento
  3. Flydigi Apex 4 Trigger Assembly Replacement: passo 3, immagine 1 di 2 Flydigi Apex 4 Trigger Assembly Replacement: passo 3, immagine 2 di 2
    • Insert a plastic opening tool into the seam between the front and back shell along the bottom edge of the controller.
    • Gently run the opening tool along the seam to release the plastic clips holding the two halves together.
    • Work your way around all edges until the back shell is fully unclipped.
    • Carefully lift the back shell away from the front half and set it aside.
    • Do not force the shell open. If you feel strong resistance, check for any screws you may have missed.
    Chiedi a FixBot
    Aggiungi Commento
  4. Flydigi Apex 4 Trigger Assembly Replacement: passo 4, immagine 1 di 1
    • With the controller open, identify the trigger assembly on the side you are replacing.
    • The trigger assembly consists of the trigger lever, the spring mechanism, and the analog sensor attached to the internal frame.
    • Take a photo of the internal layout before removing any components. This will help you reassemble the controller correctly.
    Chiedi a FixBot
    Aggiungi Commento
  5. Flydigi Apex 4 Trigger Assembly Replacement: passo 5, immagine 1 di 3 Flydigi Apex 4 Trigger Assembly Replacement: passo 5, immagine 2 di 3 Flydigi Apex 4 Trigger Assembly Replacement: passo 5, immagine 3 di 3
    • Use a spudger or your fingernail to gently flip up the locking tab on the connector linking the trigger assembly to the main PCB.
    • Carefully pull the ribbon cable straight out of the connector.
    • Do not pull at an angle, as this may tear the cable.
    Chiedi a FixBot
    Aggiungi Commento
  6. Flydigi Apex 4 Trigger Assembly Replacement: passo 6, immagine 1 di 2 Flydigi Apex 4 Trigger Assembly Replacement: passo 6, immagine 2 di 2
    • Use a Phillips #00 screwdriver to remove the screws securing each trigger assembly.
    • Lift the trigger assembly straight up and out of the controller frame.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
janavi
Membro da: 03/23/25
241 Reputazione
2 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 6
Ultimi 7 giorni: 22
Ultimi 30 giorni: 86
Tutti i Tempi: 140
