Salta al contenuto principale
Fitbit Blaze Vibration Motor Replacement
Cosa ti serve
    1. Fitbit Blaze  Vibration Motor Replacement, Wristband: passo 1, immagine 1 di 2 Fitbit Blaze  Vibration Motor Replacement, Wristband: passo 1, immagine 2 di 2
      • Locate the front LCD screen on your device.
      • Fitbit logo should appear in the bottom center of the screen.
      Chiedi a FixBot
      Aggiungi Commento
    2. Fitbit Blaze  Vibration Motor Replacement: passo 2, immagine 1 di 1
      • Push the screen out through the back of the metal ring enclosure.
      • Use a small amount of force on screen to prevent damage. Use other hand to catch screen.
      Chiedi a FixBot
      Aggiungi Commento
    3. Fitbit Blaze  Vibration Motor Replacement: passo 3, immagine 1 di 3 Fitbit Blaze  Vibration Motor Replacement: passo 3, immagine 2 di 3 Fitbit Blaze  Vibration Motor Replacement: passo 3, immagine 3 di 3
      • Locate the metal pin behind the wristband located on the edge of metal ring.
      • Insert the pointed end of the metal spudger into the pin hold and push it into the blue rectangle enclosure.
      • Use a small amount of force to avoid damaging the pins.
      • Remove wristband.
      Chiedi a FixBot
      Aggiungi Commento
    1. Fitbit Blaze  Vibration Motor Replacement, Display Frame: passo 4, immagine 1 di 3 Fitbit Blaze  Vibration Motor Replacement, Display Frame: passo 4, immagine 2 di 3 Fitbit Blaze  Vibration Motor Replacement, Display Frame: passo 4, immagine 3 di 3
      • Locate the pin behind the second wristband located on the edge of metal ring.
      • Insert the pointed end of the metal spudger into the pin hold and push it into opposite direction.
      • Remove wristband.
      Chiedi a FixBot
      Aggiungi Commento
    1. Fitbit Blaze  Vibration Motor Replacement, Vibration Motor: passo 5, immagine 1 di 3 Fitbit Blaze  Vibration Motor Replacement, Vibration Motor: passo 5, immagine 2 di 3 Fitbit Blaze  Vibration Motor Replacement, Vibration Motor: passo 5, immagine 3 di 3
      • Place device screen face down and locate the four screws attaching the back cover.
      • Use a T3 torx head or T3 torx screwdriver to remove the four screws.
      Chiedi a FixBot
      Aggiungi Commento
    2. Fitbit Blaze  Vibration Motor Replacement: passo 6, immagine 1 di 3 Fitbit Blaze  Vibration Motor Replacement: passo 6, immagine 2 di 3 Fitbit Blaze  Vibration Motor Replacement: passo 6, immagine 3 di 3
      • Grab the back, lift and open like a book to expose the motherboard. Locate the ribbon connector on the left.
      • Use a plastic spudger tool on the ribbon connected from the heart rate monitor to the motherboard.
      • Insert and lift the plastic opening tool to release the ribbon.
      • Only a small force when lifting the plastic connector is needed to avoid damage.
      Chiedi a FixBot
      Aggiungi Commento
    3. Fitbit Blaze  Vibration Motor Replacement: passo 7, immagine 1 di 3 Fitbit Blaze  Vibration Motor Replacement: passo 7, immagine 2 di 3 Fitbit Blaze  Vibration Motor Replacement: passo 7, immagine 3 di 3
      • Separate the back and set aside, locate the three screws attaching the motherboard.
      • Use a PH000 head or a PH000 screwdriver to remove the three screws.
      Chiedi a FixBot
      Aggiungi Commento
    4. Fitbit Blaze  Vibration Motor Replacement: passo 8, immagine 1 di 3 Fitbit Blaze  Vibration Motor Replacement: passo 8, immagine 2 di 3 Fitbit Blaze  Vibration Motor Replacement: passo 8, immagine 3 di 3
      • Use a plastic spudger tool on the ribbons connected to the motherboard.
      • Insert the tool under the ribbon and lift to release the connection.
      Chiedi a FixBot
      Aggiungi Commento
    5. Fitbit Blaze  Vibration Motor Replacement: passo 9, immagine 1 di 3 Fitbit Blaze  Vibration Motor Replacement: passo 9, immagine 2 di 3 Fitbit Blaze  Vibration Motor Replacement: passo 9, immagine 3 di 3
      • Lift and push the motherboard to the side to uncover the 167mAh battery.
      • Use a plastic spudger tool to pry out the battery from its adhesive plastic underneath.
      • Lift up and pull downward to remove battery. Switch to the top portion of the battery and push downward to pry out battery.
      Chiedi a FixBot
      Aggiungi Commento
    6. Fitbit Blaze  Vibration Motor Replacement: passo 10, immagine 1 di 2 Fitbit Blaze  Vibration Motor Replacement: passo 10, immagine 2 di 2
      • Flip the motherboard back to the front to locate the metal pins from the vibration motor soldered to the board.
      • Desolder the connection to remove the motor component.
      • Follow this guide on how to solder and desolder connectors Soldering Guide
      • Excessive heat will damage the components, so do not apply the soldering iron to the component for long amounts of time.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
USF Tampa, Team S3-G3, Sullivan Spring 2017 Membro di USF Tampa, Team S3-G3, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G3
4 Membri
15 guide realizzate
4Commenti sulla guida
anyone got a part number or a description of the motor that gets replaced. looking to do this and fix. thanks
Ben - Rispondi Condividi
And how many destroyed “FitBit Blaze” are we going to see now?
tjhbob - Rispondi Condividi
what kind of motor can you replace this with?
dbick - Rispondi Condividi
Any idea what is the value of the C3 capacitor?
P J - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 10
Ultimi 30 giorni: 28
Tutti i Tempi: 3,649
