Salta al contenuto principale
Equity Alarm Clock 13014 Alarm Switch Replacement
Cosa ti serve
    1. Equity Alarm Clock 13014 Alarm Switch Replacement, Replacing the alarm switch: passo 1, immagine 1 di 3 Equity Alarm Clock 13014 Alarm Switch Replacement, Replacing the alarm switch: passo 1, immagine 2 di 3 Equity Alarm Clock 13014 Alarm Switch Replacement, Replacing the alarm switch: passo 1, immagine 3 di 3
      • Remove the battery door using your finger nail or an opening tool.
      Chiedi a FixBot
      Aggiungi Commento
    2. Equity Alarm Clock 13014 Alarm Switch Replacement, Remove screws: passo 2, immagine 1 di 2 Equity Alarm Clock 13014 Alarm Switch Replacement, Remove screws: passo 2, immagine 2 di 2
      • Use a Phillips #1 screwdriver to remove the 3 screws on the back cover.
      Chiedi a FixBot
      Aggiungi Commento
    3. Equity Alarm Clock 13014 Alarm Switch Replacement, Remove Cover: passo 3, immagine 1 di 1
      • Remove the back cover gently.
      • DO NOT pull the back cover off quickly or you may damage the wires connected.
      Chiedi a FixBot
      Aggiungi Commento
    4. Equity Alarm Clock 13014 Alarm Switch Replacement: passo 4, immagine 1 di 2 Equity Alarm Clock 13014 Alarm Switch Replacement: passo 4, immagine 2 di 2
      • Use a Phillips #1 screwdriver to remove the small screw located above the alarm switch.
      • Remove the small screw located below the alarm switch as well.
      Chiedi a FixBot
      Aggiungi Commento
    5. Equity Alarm Clock 13014 Alarm Switch Replacement: passo 5, immagine 1 di 2 Equity Alarm Clock 13014 Alarm Switch Replacement: passo 5, immagine 2 di 2
      • Place the end of the soldering iron on the end of the wire connected to the copper cylinder to detach the wire.
      • If you are unfamiliar with soldering, take a look at this article: How to Solder and Desolder Connections.
      • To replace the alarm switch, attach one end of new alarm switch wire to the copper cylinder.
      • Use a Phillips #1 screwdriver to reinstall the switch screws.
      • Follow steps in reverse order to assemble the clock.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 15
Ultimi 30 giorni: 55
Tutti i Tempi: 1,973
