Salta al contenuto principale
Ematic Genesis Screen Replacement
Cosa ti serve
  1. Ematic Genesis Screen Replacement, Ematic Genesis Casing: passo 1, immagine 1 di 3 Ematic Genesis Screen Replacement, Ematic Genesis Casing: passo 1, immagine 2 di 3 Ematic Genesis Screen Replacement, Ematic Genesis Casing: passo 1, immagine 3 di 3
    • Unscrew the two (2) 1.3mm Phillips #00 screws found on the bottom edge of the tablet, where the power and volume buttons are located.
    Chiedi a FixBot
    Aggiungi Commento
  2. Ematic Genesis Screen Replacement: passo 2, immagine 1 di 3 Ematic Genesis Screen Replacement: passo 2, immagine 2 di 3 Ematic Genesis Screen Replacement: passo 2, immagine 3 di 3
    • Insert plastic opening tool into the edge between the screen plate and the back plate to create a separation between the casings.
    • Insert the flat end of the spudger next to the plastic opening tool and carefully pry the edges apart. Continue this all around the edges until the casings separate.
    • There may be cracking sounds when prying them apart. If carefully done, this is only the locks coming apart and is not harmful.
    • Be careful when separating the two plates as they are connected by the speaker wires and could be disconnected during this process.
    Chiedi a FixBot
    Aggiungi Commento
  3. Ematic Genesis Screen Replacement: passo 3, immagine 1 di 1
    • Remove back plate from screen plate and lay both down flat next to each other.
    Chiedi a FixBot
    Aggiungi Commento
  4. Ematic Genesis Screen Replacement, Battery: passo 4, immagine 1 di 3 Ematic Genesis Screen Replacement, Battery: passo 4, immagine 2 di 3 Ematic Genesis Screen Replacement, Battery: passo 4, immagine 3 di 3
    • Lift up the two pieces of tape holding the copper plate and the connector ribbon to the battery. Gently hold or place away from the battery.
    Chiedi a FixBot
    Aggiungi Commento
  5. Ematic Genesis Screen Replacement: passo 5, immagine 1 di 3 Ematic Genesis Screen Replacement: passo 5, immagine 2 di 3 Ematic Genesis Screen Replacement: passo 5, immagine 3 di 3
    Strumento utilizzato in questo passaggio:
    Plastic Cards
    $2.99
    • Using a plastic card, gently break the adhesive that holds the battery to the metal screen plate.
    • The battery is very bendable. Although it may not be working, there are still dangerous contents inside batteries.
    Chiedi a FixBot
    Aggiungi Commento
  6. Ematic Genesis Screen Replacement: passo 6, immagine 1 di 1
    • If replacing the battery, disconnect the wires that connect the battery to the motherboard.
    • If not replacing the battery, do NOT disconnect the wires.
    • To reconnect the new battery, a soldering kit will be necessary. Use the iFixit soldering guide to gain further information on how to complete this step.
    • Come saldare e dissaldare componenti elettrici
    Chiedi a FixBot
    Aggiungi Commento
  7. Ematic Genesis Screen Replacement, Camera: passo 7, immagine 1 di 2 Ematic Genesis Screen Replacement, Camera: passo 7, immagine 2 di 2
    • Once the panels are separated, remove the tape holding down the ribbon connector that is connecting the camera to the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  8. Ematic Genesis Screen Replacement: passo 8, immagine 1 di 2 Ematic Genesis Screen Replacement: passo 8, immagine 2 di 2
    • Lift up the black lever of the connector that holds the camera ribbon in place.
    Chiedi a FixBot
    Aggiungi Commento
  9. Ematic Genesis Screen Replacement: passo 9, immagine 1 di 2 Ematic Genesis Screen Replacement: passo 9, immagine 2 di 2
    • Gently pull the ribbon out of the connector and lift the camera out of the casing.
    • There is adhesive holding the camera in the case. Pull up strong enough to separate the camera from the casing without damaging the components.
    Chiedi a FixBot
    Aggiungi Commento
  10. Ematic Genesis Screen Replacement, Button: passo 10, immagine 1 di 3 Ematic Genesis Screen Replacement, Button: passo 10, immagine 2 di 3 Ematic Genesis Screen Replacement, Button: passo 10, immagine 3 di 3
    • Once battery is removed, flip up the black lever of the connector that is holding the wide ribbon in place for the screen. Remove the ribbon from the connector.
    Chiedi a FixBot
    Aggiungi Commento
  11. Ematic Genesis Screen Replacement: passo 11, immagine 1 di 3 Ematic Genesis Screen Replacement: passo 11, immagine 2 di 3 Ematic Genesis Screen Replacement: passo 11, immagine 3 di 3
    • Rotate the tablet 180 degrees and flip up the black lever of the connector holding the small, yellow ribbon. Remove ribbon from the connector.
    Chiedi a FixBot
    Aggiungi Commento
  12. Ematic Genesis Screen Replacement: passo 12, immagine 1 di 3 Ematic Genesis Screen Replacement: passo 12, immagine 2 di 3 Ematic Genesis Screen Replacement: passo 12, immagine 3 di 3
    • Rotate the tablet 90 degrees and remove the three (3) 1.3 mm Phillips #00 screws that hold the motherboard in place.
    Chiedi a FixBot
    Aggiungi Commento
  13. Ematic Genesis Screen Replacement: passo 13, immagine 1 di 2 Ematic Genesis Screen Replacement: passo 13, immagine 2 di 2
    • Lift up the tape that covers the speaker wires and holds the motherboard in place.
    • This picture does not show speaker wires attached. These do NOT have to be disconnected for this.
    • Be careful not to disconnect the speaker wires from the motherboard. Otherwise, they will need to be soldered back on.
    Chiedi a FixBot
    Aggiungi Commento
  14. Ematic Genesis Screen Replacement: passo 14, immagine 1 di 2 Ematic Genesis Screen Replacement: passo 14, immagine 2 di 2
    • With the motherboard detached from the screen plate, there is now access to the electrical components under the motherboard and the mechanical button components on the back plate.
    Chiedi a FixBot
    Aggiungi Commento
  15. Ematic Genesis Screen Replacement, Screen: passo 15, immagine 1 di 2 Ematic Genesis Screen Replacement, Screen: passo 15, immagine 2 di 2
    • Once the battery and motherboard have been removed, gently bend the screen plate to pop out the metal digitizer that sits on the glass and plastic screen.
    • Be careful when bending as glass could break.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Baylor, Team 4-3, Williams Spring 2015 Membro di Baylor, Team 4-3, Williams Spring 2015
BU-WILLIAMS-S15S4G3
3 Membri
12 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 5
Ultimi 30 giorni: 22
Tutti i Tempi: 1,461
