Salta al contenuto principale
Ematic Genesis Battery Replacement
Cosa ti serve
  1. Ematic Genesis Battery Replacement, Ematic Genesis Casing: passo 1, immagine 1 di 3 Ematic Genesis Battery Replacement, Ematic Genesis Casing: passo 1, immagine 2 di 3 Ematic Genesis Battery Replacement, Ematic Genesis Casing: passo 1, immagine 3 di 3
    • Unscrew the two (2) 1.3mm Phillips #00 screws found on the bottom edge of the tablet, where the power and volume buttons are located.
    Chiedi a FixBot
    Aggiungi Commento
  2. Ematic Genesis Battery Replacement: passo 2, immagine 1 di 3 Ematic Genesis Battery Replacement: passo 2, immagine 2 di 3 Ematic Genesis Battery Replacement: passo 2, immagine 3 di 3
    • Insert plastic opening tool into the edge between the screen plate and the back plate to create a separation between the casings.
    • Insert the flat end of the spudger next to the plastic opening tool and carefully pry the edges apart. Continue this all around the edges until the casings separate.
    • There may be cracking sounds when prying them apart. If carefully done, this is only the locks coming apart and is not harmful.
    • Be careful when separating the two plates as they are connected by the speaker wires and could be disconnected during this process.
    Chiedi a FixBot
    Aggiungi Commento
  3. Ematic Genesis Battery Replacement: passo 3, immagine 1 di 1
    • Remove back plate from screen plate and lay both down flat next to each other.
    Chiedi a FixBot
    Aggiungi Commento
  4. Ematic Genesis Battery Replacement, Battery: passo 4, immagine 1 di 3 Ematic Genesis Battery Replacement, Battery: passo 4, immagine 2 di 3 Ematic Genesis Battery Replacement, Battery: passo 4, immagine 3 di 3
    • Lift up the two pieces of tape holding the copper plate and the connector ribbon to the battery. Gently hold or place away from the battery.
    Chiedi a FixBot
    Aggiungi Commento
  5. Ematic Genesis Battery Replacement: passo 5, immagine 1 di 3 Ematic Genesis Battery Replacement: passo 5, immagine 2 di 3 Ematic Genesis Battery Replacement: passo 5, immagine 3 di 3
    Strumento utilizzato in questo passaggio:
    Plastic Cards
    $2.99
    • Using a plastic card, gently break the adhesive that holds the battery to the metal screen plate.
    • The battery is very bendable. Although it may not be working, there are still dangerous contents inside batteries.
    Chiedi a FixBot
    Aggiungi Commento
  6. Ematic Genesis Battery Replacement: passo 6, immagine 1 di 1
    • If replacing the battery, disconnect the wires that connect the battery to the motherboard.
    • If not replacing the battery, do NOT disconnect the wires.
    • To reconnect the new battery, a soldering kit will be necessary. Use the iFixit soldering guide to gain further information on how to complete this step.
    • Come saldare e dissaldare componenti elettrici
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Baylor, Team 4-3, Williams Spring 2015 Membro di Baylor, Team 4-3, Williams Spring 2015
BU-WILLIAMS-S15S4G3
3 Membri
12 guide realizzate
1Commento della guida
tienen el firmware disponible?
Danny Abreu Victoriano - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 31
Tutti i Tempi: 1,490
