Salta al contenuto principale
Dymo LabelManager 280 Screen Replacement
Cosa ti serve
    1. Dymo LabelManager 280 Screen Replacement, Rear Case: passo 1, immagine 1 di 2 Dymo LabelManager 280 Screen Replacement, Rear Case: passo 1, immagine 2 di 2
      • Remove battery.
      • Remove the label cassette.
      Chiedi a FixBot
      Aggiungi Commento
    2. Dymo LabelManager 280 Screen Replacement: passo 2, immagine 1 di 2 Dymo LabelManager 280 Screen Replacement: passo 2, immagine 2 di 2
      • Remove the two rubber feets
      • Remove the 6 screws in the indicated places. These particular screws are 2mm x 8mm Phillips #0 head
      Chiedi a FixBot
      Aggiungi Commento
    3. Dymo LabelManager 280 Screen Replacement: passo 3, immagine 1 di 2 Dymo LabelManager 280 Screen Replacement: passo 3, immagine 2 di 2
      • Use the spudger to take apart the device by insterting it as shown in the picture and twisting it. This should be done all around the device to ensure the two parts split correctly.
      • The keys/buttons highlighted in the second picture fall out easily so be careful. Keep device faced down in order to keep them from falling.
      Chiedi a FixBot
      Aggiungi Commento
    1. Dymo LabelManager 280 Screen Replacement, Screen: passo 4, immagine 1 di 1
      • Further remove the 2 screws (1.2mm X 4mm Phillips #0 head).
      Chiedi a FixBot
      Aggiungi Commento
    2. Dymo LabelManager 280 Screen Replacement: passo 5, immagine 1 di 2 Dymo LabelManager 280 Screen Replacement: passo 5, immagine 2 di 2
      • Detach the ribbon cable.
      Chiedi a FixBot
      Aggiungi Commento
    3. Dymo LabelManager 280 Screen Replacement: passo 6, immagine 1 di 1
      • Remove the screen.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
USF Tampa, Team 6-5, Eyestone Spring 2016 Membro di USF Tampa, Team 6-5, Eyestone Spring 2016
USFT-EYESTONE-S16S6G5
3 Membri
4 guide realizzate
1Commento della guida
Hi, thak you for the tutorial, it seems pretty simple. Do you know where to find the LCD screen, or whats the specs, maybe I can find it at AliExpress.
Jacques Maltais - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 15
Ultimi 30 giorni: 48
Tutti i Tempi: 4,821
