Salta al contenuto principale
Cosa ti serve
Questo smontaggio non è una guida di riparazione. Per riparare il tuo iClicker, usa il nostro manuale di assistenza.
  1. Disassembling iClicker Device, Disassembling iClicker Device: passo 1, immagine 1 di 1
    • Behold the iclicker in all its interactive and educational beauty.
    Chiedi a FixBot
  2. Disassembling iClicker Device: passo 2, immagine 1 di 1
    • Place the device on a flat surface, buttons facing down.
    • Remove the battery cover and the three batteries within.
    Chiedi a FixBot
  3. Disassembling iClicker Device: passo 3, immagine 1 di 2 Disassembling iClicker Device: passo 3, immagine 2 di 2
    • Remove the two visible screws using a #00 Phillips screwdriver.
    • Oops! Don't forget a hidden third screw beneath the factory label.
    • Peel back the corner of the label to reveal the hidden screw.
    • If you wish to maintain the integrity of the label, a blowdryer may be used to soften the adhesive on the label before removal.
    Chiedi a FixBot
  4. Disassembling iClicker Device: passo 4, immagine 1 di 2 Disassembling iClicker Device: passo 4, immagine 2 di 2
    • Depending on how much abuse your iclicker has endured, you might be able to separate the front and rear panels of the iclicker with your fingers.
    • For the more resistent iclickers, a spudger may be employed to separate the pieces.
    Chiedi a FixBot
  5. Disassembling iClicker Device: passo 5, immagine 1 di 1
    • Your iclicker is now exposed for all its worth.
    • The back panel can be set aisde, as the remaining components are housed in the front panel.
    Chiedi a FixBot
  6. Disassembling iClicker Device: passo 6, immagine 1 di 2 Disassembling iClicker Device: passo 6, immagine 2 di 2
    • Using a spudger, gently pry the battery connectors from the front panel.
    Chiedi a FixBot
  7. Disassembling iClicker Device: passo 7, immagine 1 di 1
    • If your circuit board is stuck in the front panel, use a spudger to lift the circuit board from the front panel.
    Chiedi a FixBot
  8. Disassembling iClicker Device: passo 8, immagine 1 di 1
    • The buttons can be easily removed from the front assembly sans spudger.
    Chiedi a FixBot
  9. Disassembling iClicker Device: passo 9, immagine 1 di 1
    • Don't lose the small LED cover sitting precariously in the front panel.
    Chiedi a FixBot
  10. Disassembling iClicker Device: passo 10, immagine 1 di 1
    • Your iclicker is now disassembled.
    Chiedi a FixBot
1Commento della guida
What is an iClicker ?
furbies - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 5
Ultimi 30 giorni: 44
Tutti i Tempi: 8,148
