Salta al contenuto principale
Disassembling Logitech MBJ58 Mouse Scroll wheel from mount
Cosa ti serve
  1. Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Top cover: passo 1, immagine 1 di 1
    • Hold the mouse so that the bottom is facing up.
    • Remove the single Phillips #1 screw from the bottom half of the mouse.
    Chiedi a FixBot
    Aggiungi Commento
  2. Disassembling Logitech MBJ58 Mouse Scroll wheel from mount: passo 2, immagine 1 di 2 Disassembling Logitech MBJ58 Mouse Scroll wheel from mount: passo 2, immagine 2 di 2
    • Place the mouse so that the bottom is resting against a hard surface.
    • Lift the top cover of the mouse gently, and remove it.
    Chiedi a FixBot
    Aggiungi Commento
  3. Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Removing the Logitech MBJ58 Mouse Scroll Wheel: passo 3, immagine 1 di 3 Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Removing the Logitech MBJ58 Mouse Scroll Wheel: passo 3, immagine 2 di 3 Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Removing the Logitech MBJ58 Mouse Scroll Wheel: passo 3, immagine 3 di 3
    • Locate the scroll wheel on the mouse.
    • Grab the scroll wheel with your thumb and index finger.
    • Gently lift up, to remove the scroll wheel from the mouse.
    Chiedi a FixBot
    Aggiungi Commento
  4. Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Support Spring: passo 4, immagine 1 di 2 Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Support Spring: passo 4, immagine 2 di 2
    • Locate the spring on the scroll wheel, and carefully remove the spring.
    Chiedi a FixBot
    Aggiungi Commento
  5. Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Attaching the New Spring: passo 5, immagine 1 di 2 Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Attaching the New Spring: passo 5, immagine 2 di 2
    • Place the replacement spring on the correct side of the wheel (shown in the images) with the prongs pointing down.
    Chiedi a FixBot
    Aggiungi Commento
  6. Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Disassembling Logitech MBJ58 Mouse Scroll wheel from mount: passo 6, immagine 1 di 3 Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Disassembling Logitech MBJ58 Mouse Scroll wheel from mount: passo 6, immagine 2 di 3 Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Disassembling Logitech MBJ58 Mouse Scroll wheel from mount: passo 6, immagine 3 di 3
    • Use the images to locate where the resistance spring is.
    • This spring will easily fall off.
    • Grab the scroll wheel and its mount and gently pull them apart.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 14 persone hanno completato questa guida.
Cal Poly, Team 5-14, Forte Winter 2013 Membro di Cal Poly, Team 5-14, Forte Winter 2013
CPSU-FORTE-W13S5G14
5 Membri
23 guide realizzate
7Commenti sulla guida
Excellent! I took an MBJ58 apart to remove accumulated gunk, and the resistance spring jumped onto my worktable before I noticed where it came from. Thanks for the help, well done!
Marty Swartz - Rispondi Condividi
Heh, me too. Couldn't for the life of me figure out how it went back in. Thanks for the guide!
Steve Bennett - Rispondi Condividi
Same thing happened to me...saved me a trip to the store for a new mouse!!
thanks for taking the time to post these photos!
Bill McFarland - Rispondi Condividi
huh, thank you very much, amazing guide, the only for this product in Internet , and amazingly accurate
leartzajmi - Rispondi Condividi
the resistence spring falled off on mine how do i out it back on help
Tay Carr - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 14
Ultimi 30 giorni: 60
Tutti i Tempi: 8,874
