Salta al contenuto principale
Digiland DL8006 Battery Replacement
Cosa ti serve
  1. Digiland DL8006 Battery Replacement, Battery: passo 1, immagine 1 di 3 Digiland DL8006 Battery Replacement, Battery: passo 1, immagine 2 di 3 Digiland DL8006 Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Place the device down on its front with the back facing upward.
    • Split the two faces of the device with a plastic opening tool to pry the back cover off.
    • Remove the silver/metallic tape covering the bottom end of the tablet.
    Chiedi a FixBot
    Aggiungi Commento
  2. Digiland DL8006 Battery Replacement: passo 2, immagine 1 di 3 Digiland DL8006 Battery Replacement: passo 2, immagine 2 di 3 Digiland DL8006 Battery Replacement: passo 2, immagine 3 di 3
    • Remove the red & black wire that connects the motherboard to the bottom end of the tablet.
    • Remove the ribbon cable over the battery by flipping up the plastic tab on the ZIF connector on either side of the cable and pulling it out.
    Chiedi a FixBot
    Aggiungi Commento
  3. Digiland DL8006 Battery Replacement: passo 3, immagine 1 di 2 Digiland DL8006 Battery Replacement: passo 3, immagine 2 di 2
    • Remove the red & blue cord connecting the battery to the motherboard.
    • Remove the tape connecting the motherboard to the back of the LED screen.
    • Pry open with a plastic opening tool along the top and bottom edges until the battery is free from the device.
    • Remove all the remaining tape from the battery.
    • It may be helpful to remove the motherboard prior to prying the battery out for better leverage on the edges.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 21
Tutti i Tempi: 612
