Salta al contenuto principale
DigiLand DL8006 Motherboard Replacement
Cosa ti serve
  1. DigiLand DL8006 Motherboard Replacement, Motherboard: passo 1, immagine 1 di 2 DigiLand DL8006 Motherboard Replacement, Motherboard: passo 1, immagine 2 di 2
    • Remove the backing of the tablet to reveal the internal components using a plastic opening tool.
  2. DigiLand DL8006 Motherboard Replacement: passo 2, immagine 1 di 1
    • Peel back the metallic tape connecting the motherboard to the tablet body with your fingers.
  3. DigiLand DL8006 Motherboard Replacement: passo 3, immagine 1 di 3 DigiLand DL8006 Motherboard Replacement: passo 3, immagine 2 di 3 DigiLand DL8006 Motherboard Replacement: passo 3, immagine 3 di 3
    • Remove the battery plug from the motherboard.
    • Fingers may be used to gently wiggle the connector out if it becomes stuck.
    • If battery wires are under the ribbon, Do Step #4 first.
  4. DigiLand DL8006 Motherboard Replacement: passo 4, immagine 1 di 2 DigiLand DL8006 Motherboard Replacement: passo 4, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Opening the locking tab of the ZIF connector and carefully remove the upper section of the ribbon cable from the motherboard using tweezers.
  5. DigiLand DL8006 Motherboard Replacement: passo 5, immagine 1 di 2 DigiLand DL8006 Motherboard Replacement: passo 5, immagine 2 di 2
    • Disconnect the three remaining ribbons by opening the locking tabs of the ZIF connectors and gently pulling the cables out.
    • Use tweezers to manipulate the connectors and ribbons to prevent damage.
  6. DigiLand DL8006 Motherboard Replacement: passo 6, immagine 1 di 3 DigiLand DL8006 Motherboard Replacement: passo 6, immagine 2 di 3 DigiLand DL8006 Motherboard Replacement: passo 6, immagine 3 di 3
    • Remove the 3 mounting screws from the motherboard with a Phillips #0 screwdriver.
    • One of the screws is located under a ribbon. You will need to gently peel back the cable to access it (see image 3).
  7. DigiLand DL8006 Motherboard Replacement: passo 7, immagine 1 di 1
    • Gently remove the motherboard from the case.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 11
Tutti i Tempi: 201
