Salta al contenuto principale
DigiLand DL718M Screen Replacement
Cosa ti serve
  1. DigiLand DL718M Screen Replacement, Back Panel: passo 1, immagine 1 di 1
    • Remove back panel by wedging the iFixit opening tool on all four sides of the device.
    Chiedi a FixBot
    Aggiungi Commento
  2. DigiLand DL718M Screen Replacement, Screen: passo 2, immagine 1 di 1
    • Remove two silver Phillips #0 screws along the bottom of the internal panel.
    Chiedi a FixBot
    Aggiungi Commento
  3. DigiLand DL718M Screen Replacement: passo 3, immagine 1 di 1
    • Remove the ribbon in the bottom left corner of the motherboard by lifting the black tab and sliding the ribbon out from the slot underneath the black tab.
    Chiedi a FixBot
    Aggiungi Commento
  4. DigiLand DL718M Screen Replacement: passo 4, immagine 1 di 1
    • Remove the small, circular microphone on the left side of the device by sliding it out of its slot using an opening tool.
    Chiedi a FixBot
    Aggiungi Commento
  5. DigiLand DL718M Screen Replacement: passo 5, immagine 1 di 1
    • Remove the front-facing camera in the top left corner of the device by sliding it out of its slot using an opening tool.
    Chiedi a FixBot
    Aggiungi Commento
  6. DigiLand DL718M Screen Replacement: passo 6, immagine 1 di 1
    • Remove the three black Phillips #0 screws along the left side of the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  7. DigiLand DL718M Screen Replacement: passo 7, immagine 1 di 1
    • Detach the black tape and the wire from the right side of the screen.
    Chiedi a FixBot
    Aggiungi Commento
  8. DigiLand DL718M Screen Replacement: passo 8, immagine 1 di 1
    • Remove the rear-facing camera by prying it off of the back side of the screen using the an opening tool.
    Chiedi a FixBot
    Aggiungi Commento
  9. DigiLand DL718M Screen Replacement: passo 9, immagine 1 di 1
    • Lift the motherboard and remove it from the device using an opening tool.
    • If there is any tape on the device that prohibits you from doing so, remove the tape.
    Chiedi a FixBot
    Aggiungi Commento
  10. DigiLand DL718M Screen Replacement: passo 10, immagine 1 di 1
    • Remove the ribbon above the battery by lifting the black tab and sliding the ribbon out from the slot underneath the black tab using an opening tool.
    Chiedi a FixBot
    Aggiungi Commento
  11. DigiLand DL718M Screen Replacement: passo 11, immagine 1 di 1
    • Pry the battery off of the back of the screen by wedging the iFixit opening tool underneath.
    Chiedi a FixBot
    Aggiungi Commento
  12. DigiLand DL718M Screen Replacement: passo 12, immagine 1 di 2 DigiLand DL718M Screen Replacement: passo 12, immagine 2 di 2
    • Lift the screen from the plastic casing.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
1Commento della guida
What happen after? How remove the LCD screen? ……..INCOMPLETE
jrtu2001 - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 5
Ultimi 30 giorni: 39
Tutti i Tempi: 630
