Salta al contenuto principale
Depth Sensor Node Streambed Installation Procedure
Cosa ti serve
  1. Depth Sensor Node Streambed Installation Procedure, Preparing and setting first strut channel: passo 1, immagine 1 di 3 Depth Sensor Node Streambed Installation Procedure, Preparing and setting first strut channel: passo 1, immagine 2 di 3 Depth Sensor Node Streambed Installation Procedure, Preparing and setting first strut channel: passo 1, immagine 3 di 3
    • Clear large rocks from the streambed to make it easier to install the strut channel.
    • Place cleared rocks downstream so they do not damage the node during a storm.
    • Set 5 ft steel strut channel into place.
    • Ensure the open side of the strut channel faces south so that the solar panel receives maximum sunlight! Addtionally, be careful not to deform the steel strut channel too much. A bit of deformation is okay.
    • Use the post pounder to drive the strut channel 3 ft into the stream bed.
    Chiedi a FixBot
    Aggiungi Commento
  2. Depth Sensor Node Streambed Installation Procedure, Attaching strut channel connector: passo 2, immagine 1 di 3 Depth Sensor Node Streambed Installation Procedure, Attaching strut channel connector: passo 2, immagine 2 di 3 Depth Sensor Node Streambed Installation Procedure, Attaching strut channel connector: passo 2, immagine 3 di 3
    • Place two spring strut channel nuts into the strut channel and then place the strut channel connector.
    • Two of the strut channel connector holes should be above the strut channel for connecting the top strut channel.
    • Insert two washers and screws into the nuts.
    Chiedi a FixBot
    Aggiungi Commento
  3. Depth Sensor Node Streambed Installation Procedure, Attaching additional strut channel: passo 3, immagine 1 di 3 Depth Sensor Node Streambed Installation Procedure, Attaching additional strut channel: passo 3, immagine 2 di 3 Depth Sensor Node Streambed Installation Procedure, Attaching additional strut channel: passo 3, immagine 3 di 3
    • This is what the attached strut channel connector looks like from above.
    • Place two additional spring strut channel nuts into the aluminum strut channel to be attached.
    • Insert the last two washers and screws into the nuts.
    • Use an impact driver to secure the screws into place. The impact driver should have a 3/4 '' Socket connected via a socket adapter.
    • Socket Adapter
    • This is what the extended strut channel looks like.
    Chiedi a FixBot
    Aggiungi Commento
  4. Depth Sensor Node Streambed Installation Procedure, Attaching the  strut channel arm: passo 4, immagine 1 di 3 Depth Sensor Node Streambed Installation Procedure, Attaching the  strut channel arm: passo 4, immagine 2 di 3 Depth Sensor Node Streambed Installation Procedure, Attaching the  strut channel arm: passo 4, immagine 3 di 3
    • Line up a 1 ft strut channel with a u-bracket to the vertical strut channel.
    • Put two spring strut channel nuts into the vertical strut channel. Insert two washers and screws into the u-bracket to hold the strut channel arm.
    • Use the impact driver to tighten the screws.
    • This is a what the final node holding structure looks like.
    Chiedi a FixBot
    Aggiungi Commento
  5. Depth Sensor Node Streambed Installation Procedure, Attaching the node: passo 5, immagine 1 di 3 Depth Sensor Node Streambed Installation Procedure, Attaching the node: passo 5, immagine 2 di 3 Depth Sensor Node Streambed Installation Procedure, Attaching the node: passo 5, immagine 3 di 3
    • Place two screws into the node enclosure with the 5/16'' washer and strut channel nuts on the backside.
    • You can remove the strut channel nut spring to make installation easier.
    • Slide the node into the strut channel arm.
    • The washer should be on the outside of the strut channel and the strut channel nut should be on the inside.
    • Tighten the screws with a 3/8 inch wrench.
    Chiedi a FixBot
    Aggiungi Commento
  6. Depth Sensor Node Streambed Installation Procedure, Attaching the lock: passo 6, immagine 1 di 1
    • Create a 4 number lock combination.
    • Projects have set lock combinations. Ask the lab for guidance.
    Chiedi a FixBot
    Aggiungi Commento
  7. Depth Sensor Node Streambed Installation Procedure, Measuring starting depth: passo 7, immagine 1 di 3 Depth Sensor Node Streambed Installation Procedure, Measuring starting depth: passo 7, immagine 2 di 3 Depth Sensor Node Streambed Installation Procedure, Measuring starting depth: passo 7, immagine 3 di 3
    • Using a tape measure, measure the length from the bottom of the ultrasonic depth sensor to the water surface.
    • Measure the length from the bottom of the ultrasonic depth sensor to the bottom of the stream bed.
    Chiedi a FixBot
    Aggiungi Commento
  8. Depth Sensor Node Streambed Installation Procedure, Trim foliage that may block solar panel: passo 8, immagine 1 di 2 Depth Sensor Node Streambed Installation Procedure, Trim foliage that may block solar panel: passo 8, immagine 2 di 2
    • If foliage may block the solar panel from charging, trim some branches.
    • This is a completely installed stream bed depth sensor node!
    Chiedi a FixBot
    Aggiungi Commento
  9. Depth Sensor Node Streambed Installation Procedure, Attaching additional strut channel arm: passo 9, immagine 1 di 2 Depth Sensor Node Streambed Installation Procedure, Attaching additional strut channel arm: passo 9, immagine 2 di 2
    • Sometimes two strut channel arms are preferred over one.
    • Attach a second 1 ft strut channel arm using the same hardware as the first strut channel arm.
    • Use the node enclosure to determine how far apart the two arms need to be.
    • Tighten the screws with the impact drill.
    Chiedi a FixBot
    Aggiungi Commento
  10. Depth Sensor Node Streambed Installation Procedure, Attaching node to two arms: passo 10, immagine 1 di 3 Depth Sensor Node Streambed Installation Procedure, Attaching node to two arms: passo 10, immagine 2 di 3 Depth Sensor Node Streambed Installation Procedure, Attaching node to two arms: passo 10, immagine 3 di 3
    • Place four screws into the node enclosure with the washer and strut channel nuts on the backside.
    • This is what the node looks like attached to two strut channel arms.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Brooke Mason
Membro da: 05/29/19
2.958 Reputazione
17 guide realizzate
Open-Storm Membro di Open-Storm
Community
14 Membri
24 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 6
Ultimi 30 giorni: 27
Tutti i Tempi: 646
