Salta al contenuto principale
Dell XPS 15 9560 Battery Replacement
Cosa ti serve
  1. Dell XPS 15 9560 Battery  Replacement, Back Panel: passo 1, immagine 1 di 1
    • Before beginning, unplug the charger and any peripheries. If possible, discharge your battery below 25%.
    • Shut the laptop down.
  2. Dell XPS 15 9560 Battery  Replacement: passo 2, immagine 1 di 1
    • Remove the ten 4.0 mm screws from the back panel of the laptop using a T5 Torx screwdriver.
  3. Dell XPS 15 9560 Battery  Replacement: passo 3, immagine 1 di 1
    • Remove the two 5 mm screws underneath the XPS badge door using a Phillips screwdriver
  4. Dell XPS 15 9560 Battery  Replacement: passo 4, immagine 1 di 1
    • Use a scribe to remove the bottom base cover from the backplate.
  5. Dell XPS 15 9560 Battery  Replacement, Battery: passo 5, immagine 1 di 1
    • Using a T5 Torx screwdriver, remove the six 4.0 mm screws.
  6. Dell XPS 15 9560 Battery  Replacement: passo 6, immagine 1 di 1
    • Use your fingernails to gently "walk" the battery connector directly out of its socket.
  7. Dell XPS 15 9560 Battery  Replacement: passo 7, immagine 1 di 1
    • Remove the battery.
Conclusione
For optimal performance, after completing this guide, calibrate your newly installed battery.
Altre 11 persone hanno completato questa guida.
Jada Houser
Membro da: 09/28/21
848 Reputazione
7 Guide realizzate
Clemson, Team 4-5, Hunter Fall 2021 Membro di Clemson, Team 4-5, Hunter Fall 2021
CLEM-HUNTER-F21S4G5
4 Membri
19 Guide realizzate
1Commento della guida
If you have an additional HDD you need to use the type H5H20 instead of the 6GPTY. The configuration as shown in picture 6 isn't possible with the 6GPTY unless you're willing to remove the HDD.
Tim - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 43
Ultimi 30 Giorni: 186
Tutti i Tempi: 13,559
