Salta al contenuto principale
Dell XPS 13 9365 2-in-1 Battery Replacement
Cosa ti serve
  1. Dell XPS 13 9365 2-in-1 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Use a Torx T4 screwdriver to remove the eight screws (M2x3) that secure the base cover to the palm-rest assembly.
  2. Dell XPS 13 9365 2-in-1 Battery Replacement: passo 2, immagine 1 di 1
    • Use your fingertips to lift the system badge open and reveal the single case screw.
    • Use a Phillips #000 screwdriver to remove the screw (M1.6x4) that secures the base cover to the palm-rest assembly.
  3. Dell XPS 13 9365 2-in-1 Battery Replacement: passo 3, immagine 1 di 1
    • Starting from the front corner of the computer, pry up the base cover using a spudger and lift the base cover off the palm-rest assembly.
  4. Dell XPS 13 9365 2-in-1 Battery Replacement: passo 4, immagine 1 di 1
    • Disconnect the battery cable from the system board.
  5. Dell XPS 13 9365 2-in-1 Battery Replacement: passo 5, immagine 1 di 1
    • Use a Phillips #000 screwdriver to remove the two screws (M1.6x4) that secure the battery to the palm-rest assembly.
  6. Dell XPS 13 9365 2-in-1 Battery Replacement: passo 6, immagine 1 di 1
    • Use a Phillips #000 screwdriver to remove the six screws (M2x3) that secure the battery to the palm-rest assembly.
  7. Dell XPS 13 9365 2-in-1 Battery Replacement: passo 7, immagine 1 di 1
    • Lift the battery off the palm-rest assembly.
Conclusione
Altre 17 persone hanno completato questa guida.
Johnathan Hammond
Membro da: 02/28/18
45.034 Reputazione
408 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.989 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 24
Ultimi 30 Giorni: 137
Tutti i Tempi: 14,157
