Salta al contenuto principale
Dell VRP100 Lens Replacement
Cosa ti serve
    1. Dell VRP100 Lens Replacement, Cover Panel: passo 1, immagine 1 di 3 Dell VRP100 Lens Replacement, Cover Panel: passo 1, immagine 2 di 3 Dell VRP100 Lens Replacement, Cover Panel: passo 1, immagine 3 di 3
      • Remove the black foam padding by peeling away slowly.
      • Remove the front and back padding from the headset by peeling away slowly.
      Chiedi a FixBot
      Aggiungi Commento
    2. Dell VRP100 Lens Replacement: passo 2, immagine 1 di 1
      • Remove the six 5.5mm PH000 screws from the cover by rotating counter-clockwise.
      • Cover panel may need to be pushed in before inserting screws.
      Chiedi a FixBot
      Aggiungi Commento
    3. Dell VRP100 Lens Replacement: passo 3, immagine 1 di 3 Dell VRP100 Lens Replacement: passo 3, immagine 2 di 3 Dell VRP100 Lens Replacement: passo 3, immagine 3 di 3
      • Remove the cover using one of the plastic opening tools, and then carefully pull it from the casing.
      Chiedi a FixBot
      Aggiungi Commento
    4. Dell VRP100 Lens Replacement: passo 4, immagine 1 di 3 Dell VRP100 Lens Replacement: passo 4, immagine 2 di 3 Dell VRP100 Lens Replacement: passo 4, immagine 3 di 3
      • Carefully remove the lens and motherboard assembly from the white casing.
      Chiedi a FixBot
      Aggiungi Commento
    1. Dell VRP100 Lens Replacement, Lens: passo 5, immagine 1 di 2 Dell VRP100 Lens Replacement, Lens: passo 5, immagine 2 di 2
      • Deattach the black cover from the lens with a metal spudger.
      • This will “click” back into place during replacement.
      Chiedi a FixBot
      Aggiungi Commento
    2. Dell VRP100 Lens Replacement: passo 6, immagine 1 di 3 Dell VRP100 Lens Replacement: passo 6, immagine 2 di 3 Dell VRP100 Lens Replacement: passo 6, immagine 3 di 3
      • Gently insert the metal spudger between the lens and the lens casing.
      • Rotate the spudger around the exterior of the lens and lens housing, separating them.
      • The lens is held in place with an adhesive that will have to be applied during reassembly.
      Chiedi a FixBot
      Aggiungi Commento
    3. Dell VRP100 Lens Replacement: passo 7, immagine 1 di 1
      • Holding the lens around the outside, gently lift it out of its housing.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Cal Poly, Team S17-G1, White Fall 2018 Membro di Cal Poly, Team S17-G1, White Fall 2018
CPSU-WHITE-F18S17G1
4 Membri
24 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 5
Ultimi 30 giorni: 37
Tutti i Tempi: 1,257
