Salta al contenuto principale
Dell Precision M3800 Battery Replacement
Cosa ti serve
  1. Dell Precision M3800 Battery Replacement, Back Cover: passo 1, immagine 1 di 2 Dell Precision M3800 Battery Replacement, Back Cover: passo 1, immagine 2 di 2
    • Be sure to power off and unplug your device before you begin your repair.
    • Use a T5 Torx screwdriver to unscrew the ten 3mm screws on the laptop back cover.
    • iFixit’s magnetic project mat is great for keeping the screws in one place.
    • Lift up the silver cover from the back panel to reveal two screws.
    • Use a Phillips screwdriver to remove the two screws underneath the silver cover.
  2. Dell Precision M3800 Battery Replacement: passo 2, immagine 1 di 1
    • Use an opening tool to pry around the edges of the back panel to loosen the panel.
    • Remove the back panel.
  3. Dell Precision M3800 Battery Replacement, Battery: passo 3, immagine 1 di 1
    • Disconnect the battery cable from the system board [1].
    • Use a Phillips screwdriver to remove the four screws securing the battery to the laptop.
    • Lift the battery off the computer [2].
Conclusione
Altre 4 persone hanno completato questa guida.
Johnathan Hammond
Membro da: 02/28/18
44.830 Reputazione
408 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.985 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 44
Tutti i Tempi: 3,751
