Salta al contenuto principale
Dell Precision 5520 Battery Replacement
Cosa ti serve
  1. Dell Precision 5520 Battery Replacement, Base Cover: passo 1, immagine 1 di 2 Dell Precision 5520 Battery Replacement, Base Cover: passo 1, immagine 2 di 2
    • Be sure to power off and unplug your device before you begin your repair.
    • Turn the system badge flap over (1) and then remove the ten M2x3 screws that secure the base cover to the computer (2).
    • Pry the edges of the base cover and lift it to remove it from the computer.
    • NOTE: Use a Torx #5 screwdriver for the base screws and a Phillips screwdriver for the two M2x8 screws inside the badge flap.
  2. Dell Precision 5520 Battery Replacement, Battery: passo 2, immagine 1 di 1
    • Disconnect the battery cable from the system board [1].
    • Remove the seven M2x4 screws that secure the battery to the computer [2].
    • Lift the battery off the computer [3].
    • Do not apply pressure to the surface of the battery
    • Do not bend
    • Do not use tools of any kind to pry on or against the battery
    • If a battery cannot be removed within the constraints above, please contact Dell technical support
Conclusione
Altre 10 persone hanno completato questa guida.
Johnathan Hammond
Membro da: 02/28/18
44.953 Reputazione
408 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.985 Guide realizzate
2 Commenti
Great directions. Simple, yet precise. Took less than five minutes.
Sam Kamara - Replica
Easy peasy. Great instruction, exact parts with exact tools. Great price. Thanks IFIXIT!
Jason W Wines - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 11
Ultimi 7 Giorni: 35
Ultimi 30 Giorni: 142
Tutti i Tempi: 12,366
