Salta al contenuto principale
Dell Precision 3541 Fan Replacement
Cosa ti serve
  1. Dell Precision 3541 Fan Replacement, Fan: passo 1, immagine 1 di 2 Dell Precision 3541 Fan Replacement, Fan: passo 1, immagine 2 di 2
    • Flip your laptop over so the bottom is facing up.
    • Use a Phillips #1 screwdriver to remove eight small screws from the bottom panel.
    • Insert the end of an opening tool into the seam between the bottom cover and frame of the device.
    • Slide it around the edges to release the clips holding it together.
    • Remove the bottom panel.
    Chiedi a FixBot
    Aggiungi Commento
  2. Dell Precision 3541 Fan Replacement: passo 2, immagine 1 di 2 Dell Precision 3541 Fan Replacement: passo 2, immagine 2 di 2
    • Remove the battery for safety On the battery, you will find one screw on the right side and two on the top. Unscrew all three carefully, putting them in a safe holding place.
    • Afterwards, locate a small black cable that runs along a crevice in the underside of the battery that connects a separate component of the device to the bottom of the battery. To do this, lift the battery up and out of its designated spot, and the cable should be apparent.
    • Carefully unplug the side that connects into the battery and remove the cable from its crevice. Then the battery will fully be removed and you can safely start removing the fan.
    Chiedi a FixBot
    Aggiungi Commento
  3. Dell Precision 3541 Fan Replacement: passo 3, immagine 1 di 3 Dell Precision 3541 Fan Replacement: passo 3, immagine 2 di 3 Dell Precision 3541 Fan Replacement: passo 3, immagine 3 di 3
    • Locate and unscrew the fan The fan is located on the top right of the bottom of the laptop.
    • The fan is located on the top right of the bottom of the laptop.
    • Once you have located the fan you should see it held in place by 3 small screws and 3 larger screws as well.
    • To unscrew, you must use a #000 or 1.5mm cross-head screwdriver to unscrew the screws.
    • Once you have removed all of the screws, locate the fan cable which is a long wire running along the bottom of the computer that is connected to the fan.
    • To remove these screws, you must change to a #00 or 2mm cross-head screwdriver.
    • Then, remove the 4 screws (2 on each side) from the wire to remove it and then carefully remove the fan.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Breydan Alva Green
Membro da: 03/03/26
147 Reputazione
Una guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 8
Ultimi 30 giorni: 38
Tutti i Tempi: 48
