Salta al contenuto principale
Dell Inspiron 15-7559 Battery Replacement
Cosa ti serve
  1. Dell Inspiron 15-7559 Battery Replacement, Back Panel: passo 1, immagine 1 di 1
    • Turn off the computer.
    • Disconnect the charging cable from the computer.
    • Failure to turn off the device and disconnect the cable could lead to personal injury or device damage.
    • Flip the computer upside down.
  2. Dell Inspiron 15-7559 Battery Replacement: passo 2, immagine 1 di 3 Dell Inspiron 15-7559 Battery Replacement: passo 2, immagine 2 di 3 Dell Inspiron 15-7559 Battery Replacement: passo 2, immagine 3 di 3
    • Remove the captive screw located on the top section of the back panel, using a Philips #1 screwdriver.
    • Keep in mind that the screw cannot be fully removed from the panel, even when fully loosened.
  3. Dell Inspiron 15-7559 Battery Replacement: passo 3, immagine 1 di 3 Dell Inspiron 15-7559 Battery Replacement: passo 3, immagine 2 di 3 Dell Inspiron 15-7559 Battery Replacement: passo 3, immagine 3 di 3
    • Use the blue, plastic opening tool to gently pry a section of the back panel open.
    • Next slide the opening tool around the back panel to disconnect the clips holding the panel in place.
    • After the clips have been disconnected, the back panel can then be easily lifted off the computer.
  4. Dell Inspiron 15-7559 Battery Replacement, Battery: passo 4, immagine 1 di 1
    • Locate the battery on the bottom left side of the laptop.
  5. Dell Inspiron 15-7559 Battery Replacement: passo 5, immagine 1 di 3 Dell Inspiron 15-7559 Battery Replacement: passo 5, immagine 2 di 3 Dell Inspiron 15-7559 Battery Replacement: passo 5, immagine 3 di 3
    • Unscrew the 5 x 2mm x 5mm screws, using the T8 Torx screwdriver.
  6. Dell Inspiron 15-7559 Battery Replacement: passo 6, immagine 1 di 3 Dell Inspiron 15-7559 Battery Replacement: passo 6, immagine 2 di 3 Dell Inspiron 15-7559 Battery Replacement: passo 6, immagine 3 di 3
    • Using the tab above the battery, raise the battery far enough to disconnect the cables attached to it.
    • Using your hand grab the white portion connecting the cables to the battery and disconnect it.
    • Do not pull on the cables directly. This would risk damaging them or tearing them from the device.
  7. Dell Inspiron 15-7559 Battery Replacement: passo 7, immagine 1 di 1
    • Now lift the battery from the device to remove it.
Conclusione
Altre 11 persone hanno completato questa guida.
UW Tacoma, Team S3-G2, Liner Fall 2017 Membro di UW Tacoma, Team S3-G2, Liner Fall 2017
UWT-LINER-F17S3G2
5 Membri
9 Guide realizzate
2 Commenti
Cool, that’s the easy part. How do you tell the UEFI that it’s okay to charge the new battery?
Stefan Bacon - Replica
is it ok to replace the 11.4V battery with the 11.1V version?
Payton DePietro - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 77
Tutti i Tempi: 16,459
