Salta al contenuto principale
Dell Inspiron 15-7547 Battery Replacement
Cosa ti serve
  1. Dell Inspiron 15-7547 Battery Replacement, Bottom Cover: passo 1, immagine 1 di 1
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Close the display and flip the laptop on its back.
    • Loosen the ten 5.0 mm-long Phillips #0 screws.
    • The four screws marked with orange will remain captive to the cover.
  2. Dell Inspiron 15-7547 Battery Replacement: passo 2, immagine 1 di 1
    • Use a spudger to pry up and loosen the back cover.
    • Remove the back cover.
  3. Dell Inspiron 15-7547 Battery Replacement, Battery: passo 3, immagine 1 di 2 Dell Inspiron 15-7547 Battery Replacement, Battery: passo 3, immagine 2 di 2
    • Remove the five 5.0 mm-long Philips #0 screws that connect the battery to the case.
  4. Dell Inspiron 15-7547 Battery Replacement: passo 4, immagine 1 di 2 Dell Inspiron 15-7547 Battery Replacement: passo 4, immagine 2 di 2
    • Lift the battery out of the case.
  5. Dell Inspiron 15-7547 Battery Replacement: passo 5, immagine 1 di 3 Dell Inspiron 15-7547 Battery Replacement: passo 5, immagine 2 di 3 Dell Inspiron 15-7547 Battery Replacement: passo 5, immagine 3 di 3
    • Pull the battery cable's pull tab towards the battery to disconnect it from the motherboard.
    • Pull parallel to the motherboard, not straight up.
    • Most of the cable is attached to the case with adhesive, which may cause slight resistance.
    • Remove the battery.
Conclusione
For optimal performance, after completing this guide, calibrate your newly installed battery.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 37
Tutti i Tempi: 2,236
