Salta al contenuto principale
Dell Inspiron 15 5577 Gaming Battery Replacement
Cosa ti serve
  1. Dell Inspiron 15 5577 Gaming Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Be sure to power off and unplug your device before you begin your repair.
    • Unscrew the back cover using a Phillips #0 screwdriver.
  2. Dell Inspiron 15 5577 Gaming Battery Replacement: passo 2, immagine 1 di 1
    • Remove the back cover using an opening tool.
  3. Dell Inspiron 15 5577 Gaming Battery Replacement: passo 3, immagine 1 di 2 Dell Inspiron 15 5577 Gaming Battery Replacement: passo 3, immagine 2 di 2
    • Use a T8 Torx driver to remove the five screws around the battery.
  4. Dell Inspiron 15 5577 Gaming Battery Replacement: passo 4, immagine 1 di 1
    • Remove the Battery Cable by gently tugging it perpendicular from the surface it is attached to.
  5. Dell Inspiron 15 5577 Gaming Battery Replacement: passo 5, immagine 1 di 1
    • Pull the battery out of the laptop by prying it away from the laptop. If you're having difficulty removing it, you can also use a plastic opening tool.
Conclusione
[deleted]
Membro da: 10/31/19
346 Reputazione
2 Guide realizzate
Un commento
Thank you, you guys rock
Random User - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 67
Tutti i Tempi: 5,281
