Introduzione
This guide will assist in replacing the battery on a Dell Inspiron 13-7373. This is not very difficult and requires very little removal of other parts of the laptop.
Cosa ti serve
Remove the ten 7.5mm Phillips #00 screws from the bottom of the laptop.
Use an opening tool to remove the bottom half of the case from the laptop.
Use a Phillips screwdriver to remove the four screws holding the battery in place.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Altre 13 persone hanno completato questa guida.
6 Commenti
can you recommend a battery model #? I want to be certain I buy the correct one.
The first step needs to be amended. There are 10 back cover screws including the central one, not 9. Additionally, the battery cable removes outward from the battery, not upward.
Hi Mike,
Thanks for the feedback! I’ll make the corrections you suggested.
I'm told that you should replace the connector cable that connects the battery to the motherboard whenever you replace the battery. However that cable doesn't come with the kit. How do I get that part?
