Salta al contenuto principale
Dell Inspiron 11-3168 Battery Replacement
Cosa ti serve
  1. Dell Inspiron 11-3168 Battery Replacement, Battery: passo 1, immagine 1 di 2 Dell Inspiron 11-3168 Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Using a Phillips #00 screwdriver, remove all nine 7.5mm screws from the bottom case of the laptop.
  2. Dell Inspiron 11-3168 Battery Replacement: passo 2, immagine 1 di 3 Dell Inspiron 11-3168 Battery Replacement: passo 2, immagine 2 di 3 Dell Inspiron 11-3168 Battery Replacement: passo 2, immagine 3 di 3
    • Remove the bottom case of the laptop by gently prying along the seam with a plastic opening tool.
  3. Dell Inspiron 11-3168 Battery Replacement: passo 3, immagine 1 di 2 Dell Inspiron 11-3168 Battery Replacement: passo 3, immagine 2 di 2
    • Remove the one 7.5mm screw that is holding the battery in place.
  4. Dell Inspiron 11-3168 Battery Replacement: passo 4, immagine 1 di 2 Dell Inspiron 11-3168 Battery Replacement: passo 4, immagine 2 di 2
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  5. Dell Inspiron 11-3168 Battery Replacement: passo 5, immagine 1 di 3 Dell Inspiron 11-3168 Battery Replacement: passo 5, immagine 2 di 3 Dell Inspiron 11-3168 Battery Replacement: passo 5, immagine 3 di 3
    • Remove the battery.
Conclusione
For optimal performance, after completing this guide, calibrate your newly installed battery.
Altre 4 persone hanno completato questa guida.
2 Commenti
Well done with the instructions. AND I just noticed you attend - attended a school in El Dorado? I grew up in Pine Bluff. Your presentation was a big help to me.
Phillip Dennis - Replica
Your are welcome Phillip. I am glad you found that repair guide to be helpful.
Matthew Roomsburg - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 17
Tutti i Tempi: 989
