Salta al contenuto principale
DROCON Ninja Camera Replacement
Cosa ti serve
    1. DROCON Ninja Camera Replacement, Battery: passo 1, immagine 1 di 3 DROCON Ninja Camera Replacement, Battery: passo 1, immagine 2 di 3 DROCON Ninja Camera Replacement, Battery: passo 1, immagine 3 di 3
      • Make sure the drone is powered off before beginning the battery replacement.
      • To turn the drone off, press and hold the black button on the top of the drone until all lights are off.
      • Firmly grasp the battery tab between your thumb and index finger.
      • Pull the battery away from the drone's body
      Chiedi a FixBot
      Aggiungi Commento
    1. DROCON Ninja Camera Replacement, Casing: passo 2, immagine 1 di 3 DROCON Ninja Camera Replacement, Casing: passo 2, immagine 2 di 3 DROCON Ninja Camera Replacement, Casing: passo 2, immagine 3 di 3
      • Using a Phillips #00 Screwdriver remove the eight 4mm screws on the bottom of the drone.
      Chiedi a FixBot
      Aggiungi Commento
    2. DROCON Ninja Camera Replacement: passo 3, immagine 1 di 2 DROCON Ninja Camera Replacement: passo 3, immagine 2 di 2
      • Gently pull white casing away from the black bottom casing
      Chiedi a FixBot
      Aggiungi Commento
    3. DROCON Ninja Camera Replacement: passo 4, immagine 1 di 3 DROCON Ninja Camera Replacement: passo 4, immagine 2 di 3 DROCON Ninja Camera Replacement: passo 4, immagine 3 di 3
      • Insert the opening tool under one of the black plastic connector slots that connects the circuit-board to the casing.
      • Gently pull the opening tool toward you to disconnect the circuit-board from the plastic casing.
      Chiedi a FixBot
      Aggiungi Commento
    1. DROCON Ninja Camera Replacement, Camera: passo 5, immagine 1 di 3 DROCON Ninja Camera Replacement, Camera: passo 5, immagine 2 di 3 DROCON Ninja Camera Replacement, Camera: passo 5, immagine 3 di 3
      • Use a Phillips #00 screwdriver to remove the 5mm screws connecting the front two motor arms to the drone's body.
      • Use your fingers to gently pull the white plastic discs out of the motor arms.
      Chiedi a FixBot
      Aggiungi Commento
    2. DROCON Ninja Camera Replacement: passo 6, immagine 1 di 2 DROCON Ninja Camera Replacement: passo 6, immagine 2 di 2
      • Grasp the motor arm and pull up and away from the drone's body.
      • Repeat this step for the other front motor arm.
      Chiedi a FixBot
      Aggiungi Commento
    3. DROCON Ninja Camera Replacement: passo 7, immagine 1 di 3 DROCON Ninja Camera Replacement: passo 7, immagine 2 di 3 DROCON Ninja Camera Replacement: passo 7, immagine 3 di 3
      • Using the Phillips #00 screwdriver, remove the two 3mm screws on the control board.
      Chiedi a FixBot
      Aggiungi Commento
    4. DROCON Ninja Camera Replacement: passo 8, immagine 1 di 3 DROCON Ninja Camera Replacement: passo 8, immagine 2 di 3 DROCON Ninja Camera Replacement: passo 8, immagine 3 di 3
      • Using the opening tool flip up the black plastic clamp that holds the camera wire to the circuit board.
      • Gently pull the camera out from the control board.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 7
Ultimi 30 giorni: 29
Tutti i Tempi: 578
