Salta al contenuto principale
DJI Phantom 2 Vision Battery Replacement
Cosa ti serve
    1. DJI Phantom 2 Vision Battery Replacement, Battery: passo 1, immagine 1 di 1
      • The battery is located on the backside of the drone. You will see a large rectangular indent protruding outward.
      • The "battery" shown in the image is for illustrative purposes only. Since the original battery was missing, we constructed this one to demonstrate the repair process. The actual battery will not stick out this much.
      Chiedi a FixBot
      Aggiungi Commento
    2. DJI Phantom 2 Vision Battery Replacement: passo 2, immagine 1 di 2 DJI Phantom 2 Vision Battery Replacement: passo 2, immagine 2 di 2
      • Remove the battery from the compartment by pinching the top and bottom pressure points near the center and pulling the battery towards you.
      Chiedi a FixBot
      Aggiungi Commento
    3. DJI Phantom 2 Vision Battery Replacement: passo 3, immagine 1 di 1
      • Clean the battery compartment using cotton swabs and isopropyl alcohol or pressurized air to remove any debris or dust inside.
      • Repeat these steps after every battery replacement to prevent damage to the drone’s internal components.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 15
Ultimi 30 giorni: 66
Tutti i Tempi: 439
