Salta al contenuto principale
Contixo V9 Motherboard Replacement
Cosa ti serve
  1. Contixo V9 Motherboard Replacement, Motherboard: passo 1, immagine 1 di 2 Contixo V9 Motherboard Replacement, Motherboard: passo 1, immagine 2 di 2
    • Find the separation line between the front and back side of the device on the outer edge of the tablet.
    • Use the plastic opening tool to pry apart the tablet, lifting the face off.
  2. Contixo V9 Motherboard Replacement: passo 2, immagine 1 di 3 Contixo V9 Motherboard Replacement: passo 2, immagine 2 di 3 Contixo V9 Motherboard Replacement: passo 2, immagine 3 di 3
    • Remove the three screws along the perimeter of the motherboard using the Phillips #000 screwdriver to unscrew.
  3. Contixo V9 Motherboard Replacement: passo 3, immagine 1 di 3 Contixo V9 Motherboard Replacement: passo 3, immagine 2 di 3 Contixo V9 Motherboard Replacement: passo 3, immagine 3 di 3
    • Locate the three golden ribbons along the perimeter of the motherboard.
    • There are two dark tabs; pull each away from the cream connection port. Once tabs are in open position remove the gold ribbon.
    • Flip up the dark tab and pull the gold ribbon away.
    • Do not pull the the cables harshly as it could rip the ribbon.
    • Reference this guide for more help with attaching or detaching cables.
  4. Contixo V9 Motherboard Replacement: passo 4, immagine 1 di 3 Contixo V9 Motherboard Replacement: passo 4, immagine 2 di 3 Contixo V9 Motherboard Replacement: passo 4, immagine 3 di 3
    • Locate the battery on the opened tablet.
    • Use the spudger or one of the blue iFixit tools to lift the battery from the base of the tablet.
    • It is possible to use your hand to pry the battery away from the base of the tablet but not recommended.
  5. Contixo V9 Motherboard Replacement: passo 5, immagine 1 di 3 Contixo V9 Motherboard Replacement: passo 5, immagine 2 di 3 Contixo V9 Motherboard Replacement: passo 5, immagine 3 di 3
    • Detach the motherboard from the battery by pressing the soldering tip tool to each of the three connection points.
    • Exercise caution when desoldering the battery.
    • The tool located in the pictures is not the soldering tip tool but rather used for reference of where to detach.
    • Reference this guide for more help with soldering and desoldering the connections.
  6. Contixo V9 Motherboard Replacement: passo 6, immagine 1 di 1
    • Remove the motherboard from the base of the device. Switch with replacement.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 88
