Salta al contenuto principale
Compaq Evo N1000v Keyboard Replacement
Cosa ti serve
    1. Compaq Evo N1000v Keyboard Replacement, LED Cover: passo 1, immagine 1 di 1
      • Flip the laptop over with the rear panel facing forward.
      Chiedi a FixBot
      Aggiungi Commento
    2. Compaq Evo N1000v Keyboard Replacement: passo 2, immagine 1 di 1
      • Using a TR8 Torx screwdriver, remove the two T8 Torx screws that secure the LED cover to the base enclosure.
      Chiedi a FixBot
      Aggiungi Commento
    3. Compaq Evo N1000v Keyboard Replacement: passo 3, immagine 1 di 1
      • Flip the laptop back over with the front facing forward. Open the screen.
      Chiedi a FixBot
      Aggiungi Commento
    4. Compaq Evo N1000v Keyboard Replacement: passo 4, immagine 1 di 1
      • Locate the F1 and F2 keys near the top left corner of the keyboard.
      Chiedi a FixBot
      Aggiungi Commento
    5. Compaq Evo N1000v Keyboard Replacement: passo 5, immagine 1 di 1
      • While holding the F1 and F2 keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
      Chiedi a FixBot
      Aggiungi Commento
    6. Compaq Evo N1000v Keyboard Replacement: passo 6, immagine 1 di 1
      • Locate the Scroll and Pause keys near the top right corner of the keyboard.
      Chiedi a FixBot
      Aggiungi Commento
    7. Compaq Evo N1000v Keyboard Replacement: passo 7, immagine 1 di 1
      • While holding the Scroll and Pause keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
      Chiedi a FixBot
      Aggiungi Commento
    8. Compaq Evo N1000v Keyboard Replacement: passo 8, immagine 1 di 2 Compaq Evo N1000v Keyboard Replacement: passo 8, immagine 2 di 2
      • Insert a spudger between the F7 and F8 keys. Lift up to remove the LED cover.
      Chiedi a FixBot
      Aggiungi Commento
    1. Compaq Evo N1000v Keyboard Replacement, Keyboard: passo 9, immagine 1 di 1
      • Lift the back edge of the keyboard and pull towards the screen.
      Chiedi a FixBot
      Aggiungi Commento
    2. Compaq Evo N1000v Keyboard Replacement: passo 10, immagine 1 di 1
      • Pull the cable and lift up to release.
      Chiedi a FixBot
      Aggiungi Commento
    3. Compaq Evo N1000v Keyboard Replacement: passo 11, immagine 1 di 1
      • Remove the keyboard.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
kim
Membro da: 04/14/10
77 Reputazione
3 guide realizzate
Cal Poly, Team 29-74, Johann Spring 2010 Membro di Cal Poly, Team 29-74, Johann Spring 2010
CPSU-JOHANN-S10S29G74
3 Membri
28 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 8
Ultimi 30 giorni: 27
Tutti i Tempi: 4,155
