Salta al contenuto principale
ClickN Kids Tablet Touch Screen Display Replacement
Cosa ti serve
    1. ClickN Kids Tablet Touch Screen Display Replacement, Touch Screen Display: passo 1, immagine 1 di 1
      • Start on the side with the camera. The screen side is black, the back side is colored
      • Insert a plastic opening tool into the space between the screen and the back side.
      Chiedi a FixBot
      Aggiungi Commento
    2. ClickN Kids Tablet Touch Screen Display Replacement: passo 2, immagine 1 di 1
      • Press the plastic opening tool in until you hear a “click” and that part of the tablet opens.
      • Press and slide the plastic opening tool around all sides of the tablet until all sides pop off.
      Chiedi a FixBot
      Aggiungi Commento
    3. ClickN Kids Tablet Touch Screen Display Replacement: passo 3, immagine 1 di 1
      • Lift the detached screen from the camera side until you can see the inside of the tablet.
      • Potential for device damage. Don't open too fast, or you might damage the ribbon cables.
      Chiedi a FixBot
      Aggiungi Commento
    4. ClickN Kids Tablet Touch Screen Display Replacement: passo 4, immagine 1 di 2 ClickN Kids Tablet Touch Screen Display Replacement: passo 4, immagine 2 di 2
      • Potential for device damage. Be careful not to damage any wires or ribbon cables during this step.
      • There are two ribbon cables to remove during this step. Each is connected to a base on the motherboard.
      • There is a black tab behind the long ribbon cable. Lift up the black tab.
      • For the ribbon cable in the back, pull the black tabs on the side out.
      • Detach the ribbon cables connecting the screen to the motherboard.
      • Remove any tape that is holding down the ribbon cables. Set it aside.
      • Once the ribbon cables are freed, separate the top and bottom sides.
      Chiedi a FixBot
      Aggiungi Commento
    5. ClickN Kids Tablet Touch Screen Display Replacement: passo 5, immagine 1 di 2 ClickN Kids Tablet Touch Screen Display Replacement: passo 5, immagine 2 di 2
      • Remove the yellow tape on the right side. Easiest side to get.
      • Remove the black and yellow tape stuck together on the left and bottom sides of the screen.
      Chiedi a FixBot
      Aggiungi Commento
    6. ClickN Kids Tablet Touch Screen Display Replacement: passo 6, immagine 1 di 1
      • Potential for device damage. Make sure the screen is facedown and level to prevent or reduce damage to the display.
      • Potential for device damage. There is an adhesive on the top edge of the display’s face. Be careful not to damage the display.
      • Flex the sides of the tablet until the clips holding the display to the screen case pop loose.
      Chiedi a FixBot
      Aggiungi Commento
    7. ClickN Kids Tablet Touch Screen Display Replacement: passo 7, immagine 1 di 2 ClickN Kids Tablet Touch Screen Display Replacement: passo 7, immagine 2 di 2
      • Be careful not to damage the display or screen case.
      • Pull the display from the top side to detach it from the screen case.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 4 persone hanno completato questa guida.
Baylor, Team 4-4, Williams Spring 2015 Membro di Baylor, Team 4-4, Williams Spring 2015
BU-WILLIAMS-S15S4G4
3 Membri
8 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 19
Ultimi 30 giorni: 53
Tutti i Tempi: 8,417
