Introduzione
This guide demonstrates how to replace the control switch in your Chef'sChoice M677 tea kettle.
Cosa ti serve
Remove the five 3/8" screws from the base of the kettle using a Phillips #1 screwdriver.
A: The power supply.
B: The two boil-dry protection switches, one on either side of the central black ring.
C: The power coupling. This fits into the baseplate when you place the kettle on it.
D: The thermostat. This is a little metal ring, half hidden by the switch cover.
E: The manual ON/OFF switch.
F: The indicator light.
G: The steam chamber. This heats the thermostat, which turns off the kettle automatically.
Remove the connectors (spaded lugs) from the circuit components as shown in the second image.
You should be able to remove each connector easily by hand. Pinch the lug between your fingers and pull in the direction of the attached wire.
If necessary, use needle-nose pliers to grasp the lug shank firmly. Gently pull the lug in the direction of the attached wire.
Gently bend the disconnected wires back and out of the work area.
Strumento utilizzato in questo passaggio:Tweezers$4.99
Remove the power supply. Align the kettle as shown, with the handle to your right. Use the 7/32" nut driver to remove the 7/32" nut from the stud that is located clockwise from where the power supply was attached.
Use tweezers to remove the split-ring lock washer located under the nut.
SECOND IMAGE: Roll the kettle over so the handle is now on your left. Use the 7/32" nut driver to remove the 7/32" nut from the final stud, which is now located counter-clockwise from where the power supply was attached.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Altre 12 persone hanno completato questa guida.
2Commenti sulla guida
OK, now I can look from the bottom. But why the switch does not keep down when I press it down I can not see or repair.
Robert
Kkkk Explicação para desmontar e comprar ferramentas.
