Salta al contenuto principale
Canon PowerShot A4000 IS Flash Replacement
Cosa ti serve
  1. Canon PowerShot A4000 IS Flash Replacement, Removing the Screws Anchoring the Front Cover: passo 1, immagine 1 di 3 Canon PowerShot A4000 IS Flash Replacement, Removing the Screws Anchoring the Front Cover: passo 1, immagine 2 di 3 Canon PowerShot A4000 IS Flash Replacement, Removing the Screws Anchoring the Front Cover: passo 1, immagine 3 di 3
    • Remove the battery and data card. Refer to the Battery Removal and Memory Card Removal guides.
    • Use a Philips head screwdriver (PH000) to remove the screws circled in the picture. Screw Sizes: 4 millimeters.
  2. Canon PowerShot A4000 IS Flash Replacement: passo 2, immagine 1 di 2 Canon PowerShot A4000 IS Flash Replacement: passo 2, immagine 2 di 2
    • Use the spudger tool to gently lever the front cover off.
  3. Canon PowerShot A4000 IS Flash Replacement, Removing the Flash: passo 3, immagine 1 di 3 Canon PowerShot A4000 IS Flash Replacement, Removing the Flash: passo 3, immagine 2 di 3 Canon PowerShot A4000 IS Flash Replacement, Removing the Flash: passo 3, immagine 3 di 3
    • The flash is not held very securely in the camera so be careful. Make sure someone is holding on to it so it does not fall out.
    • Your flash should come out very easily if you use your spudger to lever it out carefully.
    • Once the bulb piece of the flash is clear of the camera body, simply use your fingers to lift the flash clear of the camera.
Conclusione
Clemson, Team 1-3, Benson Fall 2014 Membro di Clemson, Team 1-3, Benson Fall 2014
CLEM-BENSON-F14S1G3
3 Membri
17 Guide realizzate
1Commento della guida
Hello! thank you for this flash replacement guide. I would like to know: can the flash be repaired or is it only replaceable? Thank you!
Jeiler AV - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 38
Tutti i Tempi: 1,821
