Salta al contenuto principale
Canon PowerShot A4000 IS SD Card Replacement
Cosa ti serve
  1. Canon PowerShot A4000 IS SD Card Replacement, Reinserting Memory Card: passo 1, immagine 1 di 1
    • The inside of your Canon PowerShot A4000 camera should have a picture showing how to reinsert your memory card.
    • Line the memory card up like it is shown in the camera and using your thumb, press down on the card until you hear a click. Your memory card is now back in place and ready for use.
  2. Canon PowerShot A4000 IS SD Card Replacement, Memory Card Removal: passo 2, immagine 1 di 2 Canon PowerShot A4000 IS SD Card Replacement, Memory Card Removal: passo 2, immagine 2 di 2
    • To open the battery compartment where the memory card is stored, refer to the Battery Replacement Guide.
    • The memory card is stored behind the battery on the side opposite of the lens as outlined by the red rectangle in the picture.
    • To remove the memory card, use your thumb to press down on the exposed part of the card.
    • The card will dip down further into the compartment and then you will hear a click as the card is released.
Conclusione
Clemson, Team 1-3, Benson Fall 2014 Membro di Clemson, Team 1-3, Benson Fall 2014
CLEM-BENSON-F14S1G3
3 Membri
17 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 14
Tutti i Tempi: 901
