Salta al contenuto principale
Canon PowerShot A4000 IS Battery Replacement
  1. Canon PowerShot A4000 IS Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Using your finger, apply light pressure to the grooves at the top right corner of the camera to slide the door to the battery compartment open.
  2. Canon PowerShot A4000 IS Battery Replacement, Inside The Battery Compartment: passo 2, immagine 1 di 2 Canon PowerShot A4000 IS Battery Replacement, Inside The Battery Compartment: passo 2, immagine 2 di 2
    • Using your finger, press the red switch backwards, away from the lens to release the battery.
    • The battery has an arrow on it pointing in the direction the battery needs to be oriented in the camera.
Conclusione
Clemson, Team 1-3, Benson Fall 2014 Membro di Clemson, Team 1-3, Benson Fall 2014
CLEM-BENSON-F14S1G3
3 Membri
17 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 25
Tutti i Tempi: 1,821
